Transmission help
/ Transmission help #1
JohnO
Symptoms zero turn will not move. Can anyone suggest what I should be looking for? Never had any problems prior, little of 100 hrs no issues at all.:confused:
/ Transmission help #2
Maybe some more information, so we know where to start. :confused3:
:D
/ Transmission help
Cub Cade zero turn 50 mower, mower worked fine until fuse blew, replaced it started up no problem. Tried to put mower in forward or reverse and it does nothing. Runs fine just will not move at all.
/ Transmission help #4
:D
What brand might be a good start...
First, does the machine start?
I know zip (nothing) about ZTRs, but I'd check all linkages to make sure the hydro transmission is getting input. That would include the pedals and ranges levers.
Was this sudden? That is, worked great yesterday, today nothing...
Is your hydraulic fluid to the proper level? Filter OK? If a filtering screen, is it clean?
All the above should be fairly easy to check...
EDIT: Since you answered some questions before I posted...a fuse prevented the mower from running? Or, starting? If this machine has an electronic hydro controller (something like Deere's E-Hydro), there may be an electrical problem. Check your troubleshooting guide in your manual and all the fuses.
After that, since it has few hours, suggest you contact your dealer. If you tear into it, you may void any warranty.
John Deere 4650 Tractor (A64047)
John Deere 4650...
2002 John Deere 4510 Tractor (A64047)
2002 John Deere...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
(APPROX. 35) DIAMOND PLATE DBL AXLE FENDERS (A62131)
(APPROX. 35)...
AIR VENT INC (A62131)
JOHN DEERE 6420 TRACTOR (A62130)
JOHN DEERE 6420...
