Transmission Fluid
/ Transmission Fluid #1
Texas88
Does anyone have a recommendation for buying GL-4 rated gear oil for the transmission on a 4500?
The manual says to use the following and I have been unable to find any GL-4 rated fluids. Everything is GL-5 rated which the manual says to not use.
API GL-4 SAE90EP
SAE 80W90EP
Chevron Gear lube SAE80w-90
Tranself EP80W-90
I have tried tractor supply, walmart, autozone, O'riley.
Any help would be appreciated.
/ Transmission Fluid #2
API GL-4 SAE90EP
SAE 80W90EP
Tranself EP80W-90
Not sure where you read in the manual that calls for GL-4. Use normal GL-5. what year is your 4500? BobG in VA
In the lubricants section of the operator's manual for the '00' series
for transmission oil it has a sentence that states:
Since transmission involves copper based alloys, it is strongly recommended NOT to use GL-5 rated category.
My 4500 is 2001 model.
/ Transmission Fluid #4
I just double checked my manual (I have an '02 model 6000) and the application for the transmission says"SAE80W90EP*" Below there the asterisk (*) says "*To comply API GLU-GL5"......so thats what I used to change my trans oil last winter. I found this on page 64 of my Owners Man. BobG in VA
/ Transmission Fluid #5
Use API GL-4 gear lubricant ( Extreme Pressure ) as per the
table A given. Viscosity grade of oil is to be selected based
on the expected air temperature range during the period
between oil changes.
Since Transmission involves copper based alloys, it is strongly
recommended NOT to use GL-5 category.
Following brand are recommended against SAE 80W90EP
1) Chevron RPM Multipurpose Gear Lubricant SAE80W-90.
2) Gulfgear EP 80W90
3) Tranself EP 80W90
Best of luck.......................
/ Transmission Fluid #6
When the GL-5 category came out many lubricant manufacturers were using additives in their gear oils that were harmful to the yellow metals found in manual transmissions. Since it's inception the majority of lubricants manufacturers have switched their additive chemistry to a yellow metal friendly additive package.
The safest thing to do is use either a GL-4 or multi-rated GL-4/GL-5 gear oil. A large portion of the gear oils on the market today are multi-rated.
/ Transmission Fluid #7
API GL-4 SAE90EP
SAE 80W90EP
Tranself EP80W-90
Texas88,
What does you dealer sale? :confused:
hugs, Brandi
Thank you everyone for the responses.
I talked to a technical service person at the Mahindra facility in Tomball texas which is just north of spring where I live.
He said that it is not a problem to use GL-5 rated gear lube for the transmission.
/ Transmission Fluid #9
Both penzoil and castrol have a gl4/gl5 yellow metal safe gear oil.
Penzoil is called 'gearplus'.
You can search for it's MSDS on their site.
soundguy
/ Transmission Fluid #10
I was under the impression Mahindra moved from Tomball to over by Intercontinental Airport?
hugs, Brandi
/ Transmission Fluid #11
Mahindra tractor production has moved over close to Intercontinental airport. The corporate office is still located in Tomball at this time. We are all suppose to make the move in the future. :)
"A SMILE IS A LIGHT IN THE WINDOW OF THE SOUL, INDICATING THAT THE HEART IS AT HOME."
Brenda Bradshaw
Customer Relations
Mahindra USA, Inc.
Schaben Pull-Type Sprayer (A66285)
Schaben Pull-Type...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
Quick Attach Backing Plate (A65579)
Quick Attach...
