Transmission Explaning
/ Transmission Explaning #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
Ok so I have my MX5100 with HST but I am looking at upgrading to a (6040 can't find yet_) 7040SUH. The 7040 has the 8x8 but I'm not entirely sure how this works. The dealer said you don't pick up any more speed going to a 12x12 necessarily but more power in the trans. So can I get so more explaining on how this all works?
Im looking for review and options on the SUH vs SUHD too, but I can start another thread on that too if I need. Or just message me.
/ Transmission Explaning #2
Interesting - I can't really tell what gearbox they come with, from the literature on their site.
Some of the description sounds like the L Series' FST, and some sounds like the L Series' GST?
/ Transmission Explaning #3
FST or Fully Sycronized Transmission. You have to stop to shift between low and high range. GST or Glide Shift Transmission. No stopping. More expensive. A 12x12 isn't more powerful than a 8x8, it just gives you more gears which gives you more options. Again, more expensive. Sometimes you need to be in between gears on a 8x8, but there isn't one. But the 12x12 might have it. Like a dump truck with a 18 speed. :)
/ Transmission Explaning #4
The 7040HD-1 (not SU) hydro shuttle 8x8 works like this:
To change ranges, tractor must be stopped, shuttle lever in N.
To pick a direction, move shuttle lever either F or R while in gear, clutch not necessary, but can be used. (clutch is good for a smooth start in 4th, 5th, 6th, 7th and 8th). I don't use it much (the clutch) for 1st, 2nd and 3rd unless I need control.
While in gear and moving or not, with shuttle lever in F or R, depress foot clutch and shift gears using gear shift lever (just like a manual trans car).
The same tractor equiped with a dry clutch (instead of multi-plate wet disc hydro shuttle) like a 7040SU, the clutch must be used when throwing the shuttle lever. No big deal.
I know the manual says if the 7040 HD-1 is equipped with a 3 range trans, heavy ground engaging like plowing is not to be used in the lowest range (pic of a snail). The three range trans pictographs are snail, turtle, and rabbit.
That is why I did not bother with adding the extra range. I don't need it, and for I do with it, I can't foresee a need for it. I know there is a need for it, otherwise Kubota wouldn't build one.
See if you can download an owners/operators manual for whatever tractor you are seriously considering. Always double check what the dealer feeds you. Not saying your dealer is out to get you, but the kubota line-up is extremely diversified. Can't be an expert at 'em all! Knowledge is power... :thumbsup:
2018 BMW X1 28I (A61569)
2018 BMW X1 28I...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
207278 (A52708)
207278 (A52708)
2015 VENGEANCE BUMPER PULL CAMPER (A60736)
2015 VENGEANCE...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
