Oil & Fuel transmission dip stick problem
/ transmission dip stick problem #1
Chaostamer
Viola, ID
Mahindra 3215 w/ FEL & Kubota M6040 w FEL
Greetings! I am having an issue with my 3215 HST transmission dip stick. My kid got on the tractor one day this summer and stepped on the dip stick. The result was not just a bent handle, but a chewed dipstick. I ordered a new on recently and stuck it in only to find out shortly the same result happened with the new one. Has anyone had this issue before? Any ideas as to what is going on?
/ transmission dip stick problem #2
If i remeber correctly, if the dipstick(loop on top) is facing one way ( I think the loop toward the center) it rubs something in the transmission and if you turn the opposite it does not.( facing outwards, right side).
MAHINDRA PARTS ONLINE
That is what I remember as well. However, I thought the loop pointed out. Can anyone set me straight on which direction to go? Also, I am looking for advice on how to keep this from happening again. At $40 a pop, I could look my diesel fuel fund.
/ transmission dip stick problem #4
Here's a pic of my hydraulic dip stick position. Never had an issue of stepping on it. My seat is adjusted almost all the way back, still my feet never get that far under the seat. A small child sitting in the seat and swinging their feet, I could see.
MrChris - thanks for the pic. I never had a problem until my 3 year old decided that it was cool to ride with papa. As for the picture, that position is the position I put the dipstick...So, I am back to what the devil is going on?
/ transmission dip stick problem #6
In my 11 years as a Mahindra dealer, I have not run into this problem or even heard about it. This being said I try to picture what could be causing this problem, but can't. Good luck with it.
LAWALLSTRACTOR - your post sums up where I am...stumped. Thanks for the input though. It does help me.
/ transmission dip stick problem #8
Look at the dipstick tube carefully. Compare it to one on another tractor.
If the tube has been bent, the dipstick will go into the wrong place every time...
/ transmission dip stick problem #9
My best guess is that there is a bend in the dipstick and maybe yours has bent incorrectly enough to be hitting against something rotating in the transmission or perhaps it is the incorrect length. I placed it on the right fender so you might be able to compare with your own. I also tried rotating the dipstick while in the trans to feel if there was any resistance. Didn't feel anything although I am only able to rotate maybe 120 deg with the dipstick fully seated before the handle hits the back wall or the 3 pt adjustment knob. I also tried to look into the trans dipstick hole with a flashlight. It appears the casting (rather than a metal tube) goes down about the same width and depth of the rubber gasket on the dipstick and then opens up. So again it might allow a bent incorrectly dipstick to reach a moving part.
/ transmission dip stick problem #10
I have a customer that has had this happen. We just replaced the dipstick a couple of weeks ago. The one that was chewed on was straight, no bent at all. The replacement had a bend about 3 inches from the end. The ones in the new 3616's are bent like the one Mr Chris shows about an inch below the rubber. I know that it gets against something but can't seem to recreate it at the shop.
Dave Merritt
oldgintractors.com
/ transmission dip stick problem #11
I have a similar issue with this HST dipstick. Now my concern is what damage will the metal debris cause to the hydraulics? I have also seen this problem mentioned on other tractor posts. It is also odd that a replacement is difficult to locate online.
/ transmission dip stick problem #12
This happened on my 3616 as well. My solution was to cut off the old one and use it for the installed working plug. The new one hangs on a nail in the tractor shed and is only used for checking level.
/ transmission dip stick problem #14
I had the same ideas as you can see there is a lot of metal missing from the original. The new one does have a bend that the original didn’t!
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
Excavator trenching bucket- one bucket per lot (A63689)
Excavator...
Plastic Drain Pipe (A64119)
Plastic Drain Pipe...
2002 CATERPILLAR 247 SKID STEER (A64279)
2002 CATERPILLAR...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2008 Toro Multi Pro 1200 Turf Sprayer (A61572)
2008 Toro Multi...
