Transmission Cases
/ Transmission Cases #21
there's a thread on this site somewhere where a guy busted the housing where the tow bar slides in.
Yeah I recall that thread too. I think the draw bar fell out part way while brush mowing. Wonder what would have happened to a cast unit under the same circumstance? Anyone willing to let a rotary cutter hit they're draw bar at full speed to find out?
/ Transmission Cases #22
Many years ago I had a lower arm bind up under load and pulled out a chunk from the iron casting on an International 460. A good old school welder brazed it back together and it never came apart again.
/ Transmission Cases #23
Yeah a lot depends on where the impact is and it can differ between two of the same tractors even. We had a Long tractor when I was a kid I was using it to clear brush and the box blade hooked a stump and cracked the rear housing. I'm not saying I'm pro or con aluminum housing I'm just saying they all can break.
/ Transmission Cases #24
I agree they can all break. Most of the failures I have had and have seen were due to operator error. I never seem to get stuck anymore and don't have much tear up either because I am more cautious than when I was a kid starting out. The large majority of equipment will hold up well if taken care of and used correctly.
/ Transmission Cases #25
/ Transmission Cases #26
Guess I'm not going to worry about it too much, talked to my insurance guy and he said if I hit something and break it, it's covered by my insurance.
If you hit something hard enough to break the axle, worry about the axle after you get out of the Hospital, if you do.
/ Transmission Cases #27
I do think the axle on the tractor is actually aluminum, it is the transmission housing that is aluminum.
/ Transmission Cases #28
eagle107, that was my earlier question....that was never answered....the Axle is steel versus the transmission housing that is aluminum....right?
Title of thread says it all, "Transmission Cases"
/ Transmission Cases #30
Yeah , I can read.....the tread says "Transmission Cases" and you asked about "Axles".....Or, am I missing something here?
/ Transmission Cases #32
Sorry, I meant to say, I do not think the axle on the tractor is actually aluminum, it is the transmission housing that is aluminum.
Your right I did ask about trans cases, and the call it the rear axle, I know the axle shafts are steel.
It was the trans housing it was talking about being aluminum.
/ Transmission Cases #34
Thanks, 2350......now it makes sense to me......but just making sure.
Cheers,
Mike
/ Transmission Cases #35
Guess it takes ----- to get a simple answer to a simple question, in this case, oldballs, The OP said aluminum axle twice, I had to read 4 pages to find out it's aluminum case, and since I'm here, aluminum case for a lawn tractor, sounds ok to me, but aluminum case on a bigger tractor, no way, especially it it has a FEL, and I wouldn't buy a wheel barrel with aluminum axle.
/ Transmission Cases #36
Count me among the dyslectic, IQ, spelling and grammar impaired.:laughing: But if one hangs in here long enough, he'll either get a good answer or a good laugh.
Cheers,
Mike
Reading is good for you. :D:D
2012 CATERPILLAR CP56 PADFOOT ROLLER (A65056)
2012 CATERPILLAR...
2023 Kubota Z781KWTI 62in Zero Turn Commercial Mower (A66734)
2023 Kubota...
2009 FORD CROWN VICTORIA (A66091)
2009 FORD CROWN...
2023 Polaris Utility Cart (A66738)
2023 Polaris...
2018 Toro Workman HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
2014 KAWASAKI KAF400B (A66091)
2014 KAWASAKI...
