Transmission belt pattern for LT155
   / Transmission belt pattern for LT155 #1
hoc342
taunton
JohnDeere111h
Old belt snapped off and everything I've seen tells you how to Uninstall. And then says follow the way of the old belt. Well if it snapped off you don't have a pattern. Anyone help here please?
   / Transmission belt pattern for LT155 #3
Yep, those instructions remind me of the old Chilton auto service manuals. I once had to replace a heater core on my car, so looked up how to do it at the local library Chilton book.
I swear to God, this was the instructions as best I can remember.
1. drain antifreeze
2. remove heater core
3. reverse the process to install.
Looks like i got it on right but I'm getting no forward or reverse. Is there supposed to be any play in the belt? Or is it supposed to be tight?
   / Transmission belt pattern for LT155 #5
I would say if properly installed the belt should be tight. Not unusual for springs to get launched or broken when belts break.
   / Transmission belt pattern for LT155 #6
Be sure that the spring is in the groove of the arm. If it slips up it won't drive.
   / Transmission belt pattern for LT155 #7
I have a PDF of the tech manual, if wanted message me your email and it's on the way-
from the manual -
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2014 Chevrolet...
2019 Ford F-750 Reel Loader Flatbed Truck (A56858)
2019 Ford F-750...
Sundowner Rancher Express 20FT Livestock Trailer (A56435)
Sundowner Rancher...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
