Transfer pump hose
   / Transfer pump hose
I'll still be pumping out of a small can, but I think I'll probably go with service station type 3/4" hose and a nozzle that I can grab at the local TSC.
There's a cab on this tractor, so I can't stand up in the driver's area to lean over and pour from a can like I could on my previous tractor.
   / Transfer pump hose #12
"There's a cab on this tractor, so I can't stand up in the driver's area to lean over and pour from a can like I could on my previous tractor."
Same problem for me!
Simply impossible to hold 5 gal container at arms length and pour without spilling and getting all dirty from greasy FEL arms.
I use an 'cheepo' cast iron hand crank pump (about $19.00) from a 25 gal drum mounted on an old hand cart.
To adapt a hose I welded a 1/2" NPT to hose plumbing adaptor and use auto parts fuel line that I terminated with 90 deg PVC barb to barb PVC hose elbow.
The elbow works just fine as my nozzle.
Cranking the fuel is real easy going and takes but a few mins.
Really effortless (and clean).
When full I reverse crank to empty the hose contents back to the fuel caddy.
   / Transfer pump hose #13
I have that type nozzle on my system but I got mine from Northern Tool becaus TSC was out of them at the time.
   / Transfer pump hose #14
all my local 'real' parts stores like napa/carquest sell hose by the foot.. fuel line included.
soundguy
This is a much nicer - better pump for only 68 dollars more
and the fittings to connect it to a 1/2 5/8 or other diameter hose are readily available.
If it were me I'd send the hand pump back to Northern and exchange it for this one.
As you probably recall, I did just that. The pump just arrived UPS. Now here's something funny: Remember when I said that it was the exact same pump and it was $109 compared to $140 at Northern Tool?
The receipt with the pumped looked very familiar. Just like Northern's. Had the same Ft. Mill, SC address, only the company name was Great Plains Manufacturers/Distributors.
This must be Northern's ebay branch. But I saved $31 for the pump, so I'd be the last to complain!
I know that I can get the service station type hose and nozzle at the local TSC. Finding a 15 gallon plastic drum with handle and 2 openings on top is the problem of the moment. I've got friends checking around locally and a wanted ad on the local Craigslist. Cheapest so far is $10 on ebay, but tack on another $15 to ship it to me. I'm thinking that someone with a pool close by will have one somewhere. I understand that chlorine or some pool chemical is shipped in those.
   / Transfer pump hose #16
If you need some of those 15 gallon jugs with a handle stop by your local dairy farm, they will probably be more than happy to give you a couple of truck loads of them. All the local dairy guys around here are over run with them. They get their teat wash and other dairy chemicals in them.
   / Transfer pump hose #17
1*The receipt with the pumped looked very familiar. Just like Northern's. Had the same Ft. Mill, SC address, only the company name was Great Plains Manufacturers/Distributors.
2*I know that I can get the service station type hose and nozzle at the local TSC.
3*Finding a 15 gallon plastic drum with handle and 2 openings on top is the problem at the moment. I've got friends checking around locally and a wanted ad on the local Craigslist.
4*Cheapest so far is $10 on ebay, but tack on another $15 to ship it to me.
1*Would you happen to have the name and address and part number off that receipt?
2*You can use the TSC nozzle and still go with 1/2 or 5/8 fuel line if you desire.
The nice part about that is you're not limited to just one length of hose .
3*Yep finding drums can be a challenge
I looked a long time for 30 and 55 gallon drums for my set up system.
4*The best deal I could find at first was a place in Columbus Oh. that reconditions drums.
Their drums were $25~for a 30 or 55 gallon your choice.
UPS shipping was 25 dollars per drum.
Then I got lucky a guy advertised 12 30 gallon drums in the paper.
I bought the whole lot of them for $36 and kept 2 of them for my set up and put the other 10 up for sale.
I still have one left for $15.
I still needed 3 55 gallon drums and found 1 at a flee market for $17 and 2 from a private party for $12 each.
My next door neighbor gave me a 15 gallon one just like you are talking about .
To bad you are so far away and I don't want to get rid of it.
All set now except for the fuel container. Have pump, 14 foot hose, nozzle, filter/water separator and fittings for all from TSC. Also bought a deep cycle marine battery for the pump.
LBrown - sent you a private message with the info you requested.
   / Transfer pump hose #19
1*All set now except for the fuel container.
2*Have pump, 14 foot hose, nozzle, filter/water separator and fittings for all from TSC.
3*LBrown - sent you a private message with the info you requested.
4* Also bought a deep cycle marine battery for the pump.
1*I have a 30 gallon drum I've been offering for sale in the local paper for $15 ; but I'm thinking maybe I better keep it in case I want to build another fuel storage set up later.
2*That's a real good start, keep us posted with your progress.
3*Thanks .
4*I just used this battery charger.
It was always just setting around in the way doing nothing most of the time anyway.
Powering the pump with it gave me a handy easy way to store it and it's easy to disconnect from the pump if I need the charger for something else.
Going with the Charger which i all ready had saved me the cost of buying a battery too.
This arrangment has worked out very well for me.
Here's what the setup looks like so far:
Where the 90 degree elbow is will be another straight piece of pipe going into the diesel. Now if I could only come up with one of those jugs! I may have to bite the bullet and buy one online somewhere if nobody comes up with one this week.
EZGO (A50324)
EZGO (A50324)
2008 Mazda CX9 SUV (A50324)
2008 Mazda CX9 SUV...
IH 735 5 Bottom Plow (A50515)
IH 735 5 Bottom...
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51243)
UNUSED INDUSTRIAS...
2019 Dodge Journey GT SUV (A50324)
2019 Dodge Journey...
2010 CATERPILLAR CM1210106 ROUGH TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
