Trans Problems
/ Trans Problems #1
Va Mike
Herndon, Virginia
International 350 Utility TLB, John Deere 790 w/ FEL, JD 317
I am looking at an International 3414 TLB.
It will not go in gear. The dealer is telling me that it has a broken shifter fork.
He says it is a common problem with this model and is not hard to repair.
Does anyone have any experience with this issue
Mike
/ Trans Problems #2
Mike I gotta ask the obvious: If it's a shifter fork, and it is an easy fix, why the heck doesn't the dealer do it? :confused:
Welcome to TBN!
/ Trans Problems
He said he picked up the unit at an estate auction.
He is now in combine season and doesn't have time to work on it.
Have you ever worked on the trans on one of these??
It is supposed to have a removable plate that makes this an easy repair.
I am just trying not to get ANOTHER project.
Mike
/ Trans Problems #4
The shifter fork is attached to the shifter and comes out when you remove the cover, just remove and replace, piece of cake.
/ Trans Problems #5
How can you tell if everything else works if you can't move the tractor. Tell the dealer to fix it and you will come back and check it out. Otherwise stay away from it. Just remember it always starts out as a deal and turns in to a nightmare.
/ Trans Problems #6
Mornin Mike,
I have to agree with Hooked on HP !!! For you to purchase that equipment and find out down the road that its something more involved than the shifter fork is unacceptable IMHO. Especially from a dealer. If you were buying from a private party then that another bird !!! And another arrangement!
/ Trans Problems #8
I agree. The 'ran when parked' concept is generally one of the 'great lies'
Soundguy
/ Trans Problems
I may have to use that line someday.
I am going to look at 2 machines tomorrow.
Maybe I'll get lucky on one of them
Thanks for all the info and input.
Mike
/ Trans Problems #10
If the price is right, well below market value and this type of "deal" is up your alley, go for it. When I was a kid, i would look for cars that had blown head gaskets, knocking engines and what ever would get me the car for a steel. As others have said, pull the cover and see if that is the issue and if you can get it in to gear.
I'll bet he doesn't have much in it if bought at auction with known problem.
/ Trans Problems #11
If that is the same tranny setup as my 2444 then the repair if a shifter fork should be pretty simple. The top of the tranny just lifts off and pretty much everything is right there. If a good enough deal , go for it. Thhis might be a fairly common problem, my 2444 came from the Army coprs of engineers with a spare set of shifter forks :) But they have not been used in 15 yrs either, so I don't know. Perhaps the origional ones were bad and the replacements last ?
More symptoms please, does the gears just grind when you attempt to engage them ?
Will they appear to shift but not engage ?
/ Trans Problems #12
How about the dealer supplies the part and you put it in before you buy?
Metal Bigfoot Lawn Art (A61569)
Metal Bigfoot Lawn...
2017 PETRBILT 389 6X4  T/A SLEEPER TRUCK TRACTOR (A59908)
2017 PETRBILT 389...
2015 C.GALLEGOS PNEUMATIC TRAILER (A60736)
2015 C.GALLEGOS...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61166)
IMPORTANT PLEASE...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
