trans problems with Kubota RTV900
   / trans problems with Kubota RTV900 #1
Hilltop Ranch
Kubota RTV900
Hello, bought this vehicle used, as is, just need a hand getting it going.
My RTV900 wont move in any gear, even after I checked to see if the shift forks were slipped out of position. Cables are tight and shift forks are in place OK. Some posts refer to a pressure relief knob, but I can't find one on my model( no bed dump or other hyd. outlets attached), so problem seems to be internal to trans. This is a real "bare bones" model so solution should be simple.
   / trans problems with Kubota RTV900 #2
Welcome to TBN. :)
   / trans problems with Kubota RTV900 #3
WELCOME to TBN :)
I moved your thread to the ATVs & Utility Vehicles Forum.
   / trans problems with Kubota RTV900 #4
if it doesn't move at all is the drive shaft connected?is the hydro filter blocked [the one on front of transaxle,is their oil in the unit? after these checks I beleive your going to need to locate a manual and a presure gauge for a little more in depht checking. good luck
   / trans problems with Kubota RTV900 #5
The older RTV900's did not have the pressure release valves for the transmissions. This made them a pain to shift when on a hill or pushing snow.
Ford 8340 (A53317)
Ford 8340 (A53317)
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58214)
2025 FUTURE X-DM43...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2007 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2007 Chevrolet...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
