trans problems with Kubota RTV900
   / trans problems with Kubota RTV900 #1
Hilltop Ranch
Kubota RTV900
Hello, bought this vehicle used, as is, just need a hand getting it going.
My RTV900 wont move in any gear, even after I checked to see if the shift forks were slipped out of position. Cables are tight and shift forks are in place OK. Some posts refer to a pressure relief knob, but I can't find one on my model( no bed dump or other hyd. outlets attached), so problem seems to be internal to trans. This is a real "bare bones" model so solution should be simple.
   / trans problems with Kubota RTV900 #2
Welcome to TBN. :)
   / trans problems with Kubota RTV900 #3
WELCOME to TBN :)
I moved your thread to the ATVs & Utility Vehicles Forum.
   / trans problems with Kubota RTV900 #4
if it doesn't move at all is the drive shaft connected?is the hydro filter blocked [the one on front of transaxle,is their oil in the unit? after these checks I beleive your going to need to locate a manual and a presure gauge for a little more in depht checking. good luck
   / trans problems with Kubota RTV900 #5
The older RTV900's did not have the pressure release valves for the transmissions. This made them a pain to shift when on a hill or pushing snow.
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
PT Pump (A50121)
PT Pump (A50121)
JMR 68" Root Grapple (A50121)
JMR 68" Root...
Massimo MB100 Mini Bike (A50121)
Massimo MB100 Mini...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
