Oil & Fuel Trans oil question
/ Trans oil question #1
jswisc
SE Wisconsin
204 Jinma
I changed the trans oil in my Jinma 204 over the weekend. I was going to use 80/90 gear oil but TSC didn't have 5 gal containers. Instead I used 85/140 gear oil. Seems fine but I don't recall anyone commenting on it before. Any thoughts? Tractor has 450 hours and is 4 yrs old.
/ Trans oil question #2
I use 85W140 in my tractors, and straight 140W in implement transmissions. But that's because I don't like how thin 80W90 gets here in July/August. And our winters are surely nothing like what you experience up there.
So I say try it, but be prepared for possibly extended warm-up times next winter. But if you park the tractor for the winter, I'd say it's a non-issue.
//greg//
/ Trans oil question #3
That unit have a creeper gear?
soundguy
Yes, it does have a creeper box. I took the advise of this board and lifted the cover to be sure it was filling. It was empty after I drained it and I filled it. The thicker oil probably would have made it through the bearing but I didn't want to take the chance. I also changed the front axle fluid as well. It took a very long time to fill. Oil was so thick it will take some time to get out to the ends of the diff. I removed the drains a little to check if some lube made it there. It did. I might decide to change back to 80/90 in the fall.
/ Trans oil question #6
Yep.. that's waht i was gonna mention to make sur ehte creeper got oil.. since it was the thick oil.. etc.
you are already 1-step ahead.
soundguy
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
2020 Hino 195 Landscape Dump Truck (A64556)
2020 Hino 195...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
UNUSED PARBREAK DB220-84" HYD DOZER BLADE (A65055)
UNUSED PARBREAK...
