Trans leak or Hydraulic leak
/ Trans leak or Hydraulic leak #1
3fingers
Santa Fe TX
JD 455
Morning, I seen a post for this ? but I can not seem to find it again. I have a leak some where up on right hand side of Transmission near top, it leaks when running not moving. Before dismantling to get in there any thoughts. Machine is a 1998 JD 455 with the Yanmar diesel. Thx
/ Trans leak or Hydraulic leak #2
You need to source the leak before you can fix it.
I would remove the seat, fenders, fuel tank and try and find the leak. You may have to power wash it first.
My JD 285 started to leak. It was the shaft of the hydraulic motor wore through the upper case. Upper case was NLA (no longer available). I had to source a used transaxle assembly.
Ok thx, am in tear down mode as we speak.
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
2006 CASE 430 SKID STEER (A65053)
2006 CASE 430 SKID...
2012 VOLVO L180G WHEEL LOADER (A65053)
2012 VOLVO L180G...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2011 Kenworth T800 Truck T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2011 Kenworth T800...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
