Trans Fill Plug
   / Trans Fill Plug #1
Lucid
Windsor, Virginia
IH Farmall 200
Think mine has seen better days... do I have to replace the whole cover or can I fix this somehow? :/ Was thinking of changing the fluid.
Eric
   / Trans Fill Plug #2
can you get it out? ( in one piece? )
   / Trans Fill Plug
Can't get it out yet. May try weld a bolt to it. Thanks for the suggestion.
   / Trans Fill Plug #5
yep.. I'd weld a bolt or big hex nut to it. the heat will help free it too...
   / Trans Fill Plug
I put wd40 on it overnight and tried a bigger pipe wrench. Got it off. :thumbsup:
   / Trans Fill Plug #7
Good to hear. Gonna put anti seize on the new plug? Id be tempted to use one with a male head.
   / Trans Fill Plug #8
How long had that thing sat outside???/ I once watched a retired Navy Machinist Mate take one off that looked just as bad with cold chisel and a machist hammer...did it in a matter of seconds..I thought it was never gonna get out....BobG in VA
   / Trans Fill Plug #9
yep.. I've had to tap a few around with a chissle.
I'd put some teflon paste on it before I put a new one back in. Normally I'd use a headed one.. but on that op platform. an inverted head one is likely the best call.
   / Trans Fill Plug
WilliamBos said:
Good to hesr. Gonna put anti seize on the new plug? Id be tempted to use one with a male head.
Yep need to get a new plug. Antiseize sounds like a good investment!
It's been outside too long. Building a shed roof this fall to store the tractor under. I am glad I got it free or was thinking it was going to be a pain.
17101 (A53421)
17101 (A53421)
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
Club Car Golf Cart (A51694)
Club Car Golf Cart...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
