Trans Fill Plug
   / Trans Fill Plug #1
Lucid
Windsor, Virginia
IH Farmall 200
Think mine has seen better days... do I have to replace the whole cover or can I fix this somehow? :/ Was thinking of changing the fluid.
Eric
   / Trans Fill Plug #2
can you get it out? ( in one piece? )
   / Trans Fill Plug
Can't get it out yet. May try weld a bolt to it. Thanks for the suggestion.
   / Trans Fill Plug #5
yep.. I'd weld a bolt or big hex nut to it. the heat will help free it too...
   / Trans Fill Plug
I put wd40 on it overnight and tried a bigger pipe wrench. Got it off. :thumbsup:
   / Trans Fill Plug #7
Good to hear. Gonna put anti seize on the new plug? Id be tempted to use one with a male head.
   / Trans Fill Plug #8
How long had that thing sat outside???/ I once watched a retired Navy Machinist Mate take one off that looked just as bad with cold chisel and a machist hammer...did it in a matter of seconds..I thought it was never gonna get out....BobG in VA
   / Trans Fill Plug #9
yep.. I've had to tap a few around with a chissle.
I'd put some teflon paste on it before I put a new one back in. Normally I'd use a headed one.. but on that op platform. an inverted head one is likely the best call.
   / Trans Fill Plug
WilliamBos said:
Good to hesr. Gonna put anti seize on the new plug? Id be tempted to use one with a male head.
Yep need to get a new plug. Antiseize sounds like a good investment!
It's been outside too long. Building a shed roof this fall to store the tractor under. I am glad I got it free or was thinking it was going to be a pain.
Tradewinds Power Unit (A50120)
Tradewinds Power...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
B&W Companion Sliding 5th Wheel Hitch (A53117)
B&W Companion...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
