Tranny/hdy fluid
   / Tranny/hdy fluid #1
MoKioti
Is Walmart's Super Tech Dexron-111 Mercon Auto Transmission fluid acceptable for LK3054 replcement hydraulic fluid? There are no dealers near me and I need to replace all the fluids since I bought the tractor used. thanks for any replies.
   / Tranny/hdy fluid #2
Mo. does it say hydraulic/transmission fuild. If so the answer is yes. Is there a Sam's Club nearby or Tractor Supply store. Sam's club for me was the best price
   / Tranny/hdy fluid #3
I had the same experience as Dirtcutter. I checked at TS and Sam's. I think you basically need a UTF (Universal Torque Fluid) that works for both your transmisson and hydraulics. Most of the 6 gallon pails will say UTF or will say Hydraulics/Transmission fluid and will list the tractors that it can be used for. Don't be to alarmed if Kioti isn't listed, I have yet to look at a pail that was except for TRC's oil.
   / Tranny/hdy fluid
Thanks for the quick replies. I do not believe it says UTF so I guess I should get something else. I do not belong to Sams club and the nearest TSC is 60 miles away but Walmart is right down the road. I will check with Wally World again to see if they have the UTF oil. Thanks again, I'm new to the forum and all you posters have me helped through several issues already.
By the way, even though it's used, my Kioti is way more than I expected.
   / Tranny/hdy fluid #5
I purchase my UTF at NAPA made by valvoline in big pails. Those pails get mighty heavy while pouring the UTF into the funnel.
   / Tranny/hdy fluid #6
Our local Wal-Mart carries Super Tech -Tractor hydraulic and Transmission fluid.
Napa carries tractor transmission/hydraulic fluid if you have one nearby..
   / Tranny/hdy fluid #7
I think UTF is for universal tractor fluid. I have bought it at Autozone. If you live in a humid environment, You might want to look at R&O fluid as well. It has worked well in some of my tractors. Just my view.
   / Tranny/hdy fluid #8
If there is no store nearby, why not buy it on the web?
   / Tranny/hdy fluid #9
Never seen my Wal-Mart stock tractor fluid. However I was at Sam's last week and noticed that they now carry 5 gallon buckets of Tractor hydraulic fluid. I bought my first ~7 gallon change from Auto Zone.
   / Tranny/hdy fluid #10
My local walmart sells the Rotella(Shell in other words) hydraulic fluid in the 5 gallon buckets recommended in my ck25's manual.
   / Tranny/hdy fluid
Update; Thanks for the help. I ended up buying AW 46 hydraulic oil from from Sam's at $28+ for five gallons. I was told by the salesperson that he uses it in his JD. Does anyone know what the AW stands for, I'm assuming "all weather"?
When I changed the engine oil there were two pan plugs where as the manual shows one. I removed both plugs, was this correct?
   / Tranny/hdy fluid #12
As long as your manual list "hydraulic fluid/oil" you should be fine. ISO 32 weight is more common than a ISO 46 viscosity hydraulic oil. A ISO 46 is equivelant to a SAE 15 weight oil and a ISO 32 is equivelant to a SAE 10 weight oil. The "AW" stands for anti-wear and is refering to the additive package in the oil
If the manual states you need a UTF (universal tractor fluid), power transmission fluid then DO NOT USE a hydraulic oil. These type fluids have a different additive package.
Basically if the oil you are replacing is used for only the hydraulic system then it's probably a hydraulic oil. If it is a common sump system that uses the fluid to lubricate the trans, rear end, wet clutch and wet brake systems then you need a UTF or power trans type fluid.
You can use UTF as hydraulic oil, you can not use hydraulic oil as a UTF oil.
   / Tranny/hdy fluid
Thanks for your reply DieselPower it is obvious that you know what you're talking about.
My manual calls for multi-grade transmission fluid equivalent to:
Shell Donax-TD, Donax-TM
Mobil-Mobil Fluid 423
Exxson-Torque Fluid 56
Have yet to come across any of the listed fliuds.
Can you help again?
   / Tranny/hdy fluid #14
You need a UTF type fluid, NOT a hydraulic oil.
Spec sheet for Donax TD http://www.shell-lubricants.com/products/pdf/DonaxTD.pdf
Universal Tractor Fluid's (UTF for short) are a lubricant used in common sump type systems. They have additives to deal with wet clutch and brakes, extreme preasure additives for transmission and rear gear applications, anti foam additives in addition to being used as a hydraulic oil. Hence the name "universal" tractor fluid. If you stop by most any tractor/farm supply store (like TSC) you should be able to find UTF oil. Some wholesale clubs like BJ's and Sams also have it sometimes. Your local fuel/oil supplier will also probably have it. It can be purchased online, via phone, etc... Its not hard to find if you know where to look. :)
   / Tranny/hdy fluid
Thanks for the reply, straight to the point which a newbie like me needs. UTF it is!
   / Tranny/hdy fluid #16
When it comes to knowing oils Diesel Power is "da man" to ask. His explanations are very clear and precise and since he sells oil for a living he is very knowledgable.
   / Tranny/hdy fluid #17
MoKioti - as I recall, Sam's does carry the UTF fuild in the 5 gallon buckets (even has a tractor picture on the pail).
In answer to your drain plug question, yes, drain BOTH. My oil pan has the drive shaft pass through it, creating a "well" on either side. The two plugs allow you to drain both wells.
   / Tranny/hdy fluid
Thanks for all the replies. It sure makes things easier when you're just starting out.
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
UNUSED FUTURE FTH50-(50) SHEETS OFGALVALUME (A60432)
UNUSED FUTURE...
2016 JLG T350 TOWABLE BOOM LIFT (A60429)
2016 JLG T350...
