Trailering for sissies
/ Trailering for sissies #1
jgh
Goochland & Fluvanna Counties, VA
NH TN90F; B3000 Kubota; Bobcats 430 & A300; Liebherr 621C, Exmark laser Z, 2 sawmills
20050923
I have a 14K# Pequea gooseneck trailer with beavertail, etc, for toy toting.
It has a double Bulldog jack with the usual crank. Which is what it makes out of me on a hot day when I have to turn it, esp if there is wt on the trailer (I try to avoid!).
Does anyone know of a good solution for motorizing that bad boy? I really do not look forward to cranking that **** thing. I have checked out some suggested solutions (some related to RV jacks, etc) but would like to hear if there is experience on here with a good system.
Some I have seen would simply turn the crankshaft while others would replace everything saying that trying to connect power to the existing will not work.
/forums/images/graemlins/confused.gif
Thanks!
Jim
/ Trailering for sissies #2
Go to etrailerpart They have an Atwood power jack that will lift 3500#s. You can also go to pplmotorhomes click on RV parts superstore and scroll down to jacks, levers and chocks. They have single and double units up to 8000#s.
/ Trailering for sissies #3
Does your jack or jacks have a two speed crank? If it doesn't and you want to stay with a manual jack, you can find a two speed jack at any semi trailer supply. All semi trailers I have pulled had a two speed crank. You pushed in or pulled out on the crank to select which gear you wanted. I don't want to insult your intelligents, but have you checked to see if your's was a two speed? Most heavy trailers should have them installed.
/ Trailering for sissies #4
If you are talking about something similar to the landing gear on a semi trailer, I once made an adapter for a 1/2" drill to raise and lower the 'gear on a TV production trailer. Those things are full of equipment and heavy....the drivers talk about filling the fuel tanks after crossing the scales, just to stay under 80,000 GVWR. /forums/images/graemlins/laugh.gif
/ Trailering for sissies #5
Most people in the trucking business do call them landing gear or trailer dollies. A fully loaded semi trailer will weigh about 25,000#s on the kingpin. With a two speed jack it takes very little effort to turn the crank but it takes a long time. There is a company that makes a kit that uses a 12 volt starter motor but I don't recall the name.
No, not a 2 speed (and that surprised me) and that would mean MORE crank time, but definitely easier. I have a couple of semi trailers with those type jacks. Could not raise a full one otherwise, that's for sure!
Atwood is one that makes RV equipment, sounds like a possibility, but it would have to have more than 3500 capacity for my 14K GVWR. I did look at some such systems but most involve replacing the jack, which means serious cost, etc.
Ironically I paid over 500 for the dual jack option from the factory.
There is a guard angle iron piece which also appears to be structural that would prevent me from putting a sprocket on the axle between the jacks. Bad design /forums/images/graemlins/mad.gif
I like the drill and starter motor ideas. I'd need a drill that will run on 12 VDC but that should be doable, somehow. I'll have to integrate a HD electric line when I do a winch install.
If you think of the jig to use the start motor, I'd love to know about.
Thanks for all the thoughtful replies,
Jim
/ Trailering for sissies #7
Something like this sixthwheel wouldn't be too hard to make. Any reason why you can't put a gear on the crank side of the jack and power that? On the non crank side, is there a square recess that could be driven by a regular electric or pneumatic drill?
/ Trailering for sissies #8
The jack isn't lifting 14000 lbs but a percentage, about 20% tongue weight, of the trailer weight. So 2800 lbs on the jack should be within the atwood's 3500 lb rating right?
20050929
% only? That's a though, hmm. Thanks for chiming in, I'll check it out,
Jim
/ Trailering for sissies #10
Jgh, here is a starter motor idea.
You may have to some gear reduction to get the output to spin a lot slower than what a srarter turns at.
Racing Junk
Thanks, but have you seen any for less than that $1750 price tag?
J
/ Trailering for sissies #12
I use a 14.4 volt battery drill to jack up one wheel on my one ton truck, weighing in at 8000 lbs GVW, using the jack that came with the truck. No speed reduction.
Also use it to raise & lower the spare tire.
It seems to me, if you could find a small 4 to 1 gear box & use a 12 volt drill powered from the truck battery, it would probably work fine with the gear box attached in place of the crank handle.
40' Cube Multi-Door Shipping Container (A64127)
40' Cube...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
New Holland T5070 (A64126)
New Holland T5070...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
Spirit Electric Tricycle (A64127)
Spirit Electric...
