trailer wiring
/ trailer wiring #1
John Weaver
Georgia
2000 JD 790
Not sure if this is the right forum. I have lost touch lately, anyway. I have a 1998 and 2004 (new body style) Ford F-150 pick-up trucks. Neither came with a trailer toe package, but both appear to have a plug under the dash for a brake controller. It seems to me I need a wire at the back of the truck to connect to the trailer brakes. I only have a 4 wire flat connector at the back bumper. Am I missing something? Are there diferences in the wiring for the two trucks? I hope to get one brake controller and move it between trucks as needed. Thanks, John.
/ trailer wiring #2
Hi John... I think a trailer is an attachment of sorts…
You have lights only it looks like… If you have any trailer supply or trick up your pu stores around. Look at their controllers. They will show the needed wiring and connectors.
I’ve never seen a controller that was practical to move from vehicle to vehicle. That’s not to say they are not made. You will be looking at the wiring soon so that may give you a chance to find a ‘portable’ controller. KennyV.
/ trailer wiring #3
I can not help with your Ford wiring.
I have a Tekonsha Prodigy brake controller. I purchased it from Southwest Wheel. They now have a separate site for brake controllers.
You can purchase separate plug-in pigtails and brackets that will allow installation in different vehicles.
/ trailer wiring #4
John - Here is a <font color="blue"> site </font> with some trailer connector wiring information. I had a '97 F150 and bought a CD off Ebay for the Ford manual. It showed the complete truck wiring. Helped me do some trouble shooting on my trailer lights. I did have the factory towing package however.
/ trailer wiring
Thanks for the information. I like what I read about the Prodigy. Will check with the local dealers to see what they have. Sounds like I will need to do some wiring to get the thing hooked up. John
/ trailer wiring #6
I have a Prodgidy on my truck and pull my 5th wheel, it's a wonderful brake control!
/ trailer wiring #7
On both my dodge and yukon I have the activator II by drawtite. I've never used a better controller. Good manual or auto controll.. no hassel hookup either. Heck.. my yukon and dodge had the option connecter under the das, and it plugged right in. On the yukon I then had to insert a big 30a fuse under the hood into the fuse box to supply power to the existing 7 pin trailer light plug standard ont he back., and my dodge was already wired and had power / circuit breaker for a 7 pin hookup.
Soundguy
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2019 HINO 268 26FT 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 26FT...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
(3) Pieces of Poly Pipe (A62679)
(3) Pieces of Poly...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
