Trailer wiring on 4300?
   / Trailer wiring on 4300? #1
Bob_Trevithick
Platinum Member
Williamson, NY (near Rochester)
JD 4300 MFWD
I just got my tech manual for the 4300, and I'm new to reading schematics.. but.. I found a couple of interesting items.
One is a "brake switch", and the other is called "trailer connector."
Would this suggest, perhaps, that one could tap in somewhere to wire up a connector so that a normal road trailer would have appropriate lighting including brake lights and turn signals?
That would certainly be a worthwhile addition, and might be easy if the JD already has the wiring in place.
Anyone have any ideas about this?
Thanks,
Bob
   / Trailer wiring on 4300? #2
Bob
Would that be a four wire or is it the 7 wire connector and is it wired for American or Canadian standards? And where might you place the connector?
Egon
Egon,
Looks to be the 7 wire connector, and on further examination of the book it appears to be an option.. not standard equipment. The connector appears to come with a mounting bracket, but it isn't clear (at least to me) where in the back it is mounted.
This might be more trouble than it's worth, since I'll be towing a low trailer, and my top-ROPS-mounted strobes will be very visible from behind, as should my side flashers, etc.
   / Trailer wiring on 4300? #4
<A target="_blank" HREF=http://jdpc.deere.com/servlet/com.deere.u90490.partscatalog.view.servlets.PrintPageServlet?printParams=Illustration,+Keylines>JD 42/43/4400 Trailer Wiring Harness</A>
<A target="_blank" HREF=http://jdpc.deere.com/servlet/com.deere.u90490.partscatalog.view.servlets.PrintPageServlet?printParams=Illustration,+Keylines>JD 42/43/4400 Main Wiring Harness</A>
Hi John,
Appreciate the effort, but whatever site you sent me to presented me with a username/password prompt.. and nothing else.
I guess I need to go somewhere first and sign up?
Thanks,
Bob
   / Trailer wiring on 4300? #6
<A target="_blank" HREF=http://jdpc.deere.com/pimages/MP24/MP24412________UN02FEB01.gif>JD 4300 Main Wiring Harness</A>
<A target="_blank" HREF=http://jdpc.deere.com/pimages/MP20/MP20721________UN10MAR99.gif>JD 4300 Trailer Wiring</A>
Thanks, John.. the new links worked fine!
I guess this is an optional accessory. I'll have to think about whether it's worth adding.
Appreciate your wizardry!
   / Trailer wiring on 4300? #8
John:
On the trailer wiring harness why are there 7 leads at the plugin and only 6 leads going into the conduit. Is there a splice in the conduit or is my counting in error?
Egon
   / Trailer wiring on 4300? #9
Egon,
Either the "seventh" pin is used for "Chassis/Frame ground" or could be a "dummy" pin for keying purposes...
I'll look at mine later and let you know... /w3tcompact/icons/smile.gif
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2013 Peterbilt 367 T/A A-Frame Gin Pole Truck (A55973)
2013 Peterbilt 367...
Mini Excavator 9 Piece Attachments (New/Unused) (A59225)
Mini Excavator 9...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
473 (A52708)
473 (A52708)
1994 Club Car Electric Cart (A56859)
1994 Club Car...
