Trailer towing advice needed
/ Trailer towing advice needed #71
If I understand what you are saying, it's illegal for me to bring our gooseneck horse trailer to NC? Most horse trailers with living quarters are rated over 10K. But ours is licensed (by Ohio) as a recreational vehicle.
I'm not sure about it, but I don't think one can get a CDL in Ohio without extensive training and the using a semi to pass the test with. I'm guessing they'd laugh at me and tell me to go away if I tried to get a CDL with a recreational horse trailer.
Ken
This is argued on a daily basis here. If you are for hire you need a CDL. If it is personal use you do not.
Chris
Just wait, this will be disputed 10 times over:D:D:D
/ Trailer towing advice needed #72
I'm new, not sure if this is the way or place to ask, but some 'experts' are subscribed here so please help. I have a 2005 5.4L gas, auto, F-150 ext cab long bed. The dealer said it had a F-250 axle, 10 ply tires, and can carry 7700 lb load payload. I have a 5th wheel hitch and gooseneck dump trailer to haul, carrying a dump trailer on it, so that's about 8000 lbs empty. Stacked trailers saves on transportation expense, it's a 1100 mile haul and that's what I need to do. Towing 8000 lbs, is it safe as described, although it says F-150, it seems every time I go in for an oil change, the service department tells me how heavy duty "this" truck was ordered. GVWR on the door might give me more info? By the way, it's on I-10, flat, sea level, easy ride.
http://cgi.ebay.com/NEW-7x16-GOOSEN...5|66:2|65:12|39:1|240:1309|301:1|293:1|294:50
/ Trailer towing advice needed #73
Ok, looks like you have the Heavy Version of the f-150. The reason I say that is the 7,700# GVWR. The easy way to tell is if it has the 6 lug wheels, IT IS NOT. If it has 7 lug wheels it is. They made some with 7,700# and 8,200# GVWR and a stouter axle that is 7 lug. A real F-250 axle is 8 lug so what he told you is not entirely true.
The service dept is right, these are heavy trucks for a 1/2 ton. 8,000# tow rating is nothing for this truck. What we really need to know is the max GCWR and gear set. If the truck is what you say it is it should be 15,300# and it should have 4.10 gears leaving it with 9,500# for towing.
Chris
/ Trailer towing advice needed #74
Chris
You know, in all your info given to other members, what you might want to point out is that not all F-150's in the brochure tow the same amount. Many versions have substantially reduced payloads & tow ratings due to anything from being a 4x4, a crewcab, a full tank of gas, and extra occupant or anything in the bed that steals PIN weight from the rear axle.
I think we would be misleading others into towing more than they legally can by simply quoting the maximum weight stated in the brochure for the standard cab 4x2 with no options 5 gallons of fuel in the tank and a 120 lb woman driving the truck.
/ Trailer towing advice needed #75
NEW 7x16 GOOSENECK DUMP TRAILER 14K GVWR - eBay (item 270345764648 end time Feb-26-09 14:04:54 PST)
There are no "experts" here.
I would be very afraid for anyone who takes seriously the advice & "facts" stated here about safe towing or the safe limits of your particular truck.
I've read some good advice here, but I've also read some of the scariest suggestions & advice as to what one can do with their trucks. Seriously- I fear for the safety of others on the road.
My advice would be to contact your local police dept and ask your questions to their motor vehicle carrier enforcement dept. or contact your DMV and ask for someone invloved with MVCE.
/ Trailer towing advice needed #76
I was going off of the info he gave me. Extended cab, 5.4L, HD axles, ect. My towing book show what I quoted but not knowing the axle and lug pattern I was not 100% sure and I stated that I needed more info. Not sure how I can get much clearer than that besides jump in the plane and go to his house and look at what he has.
I do not claim to be a expert but I have been towing 10,000 miles a year for the last 20 years with zero issues and have most all the payload and towing data available to me for popular tow vehicles made in the last 10 years. If given the right info I can just tell him what the manufacture states as the max for that particular vehicle with the setup I am told it has.
Chris
/ Trailer towing advice needed #77
I'd doubt it's 26K GCWR.
You don't need a class A cdl if you're over 26K. You need a class A cdl if your combined is over 26K and your trailer is over 10,000 lbs. That's federal DOT standards. That's the minimum. Some states go even further/stricter.
For example, you can tow a 10K trailer behind a 25,999 truck with an ordinary driver's license.
In NC the statute is given below. It is stricter than the federal guidelines.
License Eligibility / Requirements
There are three classes of vehicles that require a North Carolina Commercial Driver License (CDL):
Commercial Class A - Any combination of vehicles with a gross vehicle weight rating (GVWR) of 26,001 pounds or more, provided the GVWR of the vehicle or vehicles being towed is in excess of 10,000 pounds.
/ Trailer towing advice needed #78
That's the exact same thing I just said in my previous post. It's also the exact same as the federal statutes.
In your state of NC, just like my state (PA) you can legally drive a truck with a weight rating of 26,000lbs while towing a 10,000 lb trailer-no CDL required.
I don't see where that's stricter. :confused:
/ Trailer towing advice needed #79
You're correct, the requirement for the CDL is not stricter in NC. However, it appears NC does have a requirement for a specail NC Regular Class A license (non-CDL) when pulling trailers over 10K pounds. NY had a similar thing for trucks over 18,000 lbs, ie. a specail non-CDL state license; they got rid of it back in 2005 and now just go with the federal CDL specs like you mention for PA. NY does require however, a specail license endorsement and testing if you wish to operate a motorhome over 26K MGVW.
There's a parallel thread on TBN right now HERE being beat to death about the same NC thing.
/ Trailer towing advice needed #80
You guys are not reading the statute correctly...
OR...
(this is the key word)
vehicles being towed is in excess of 10,000 pounds...
That's where they get you...
Any trailer that is over 10,000 # is being towed requires CDL's...
Don't ask me how I know...lol
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
