Trailer towing advice needed
/ Trailer towing advice needed #42
Here are some pics of the truck and trailer.
http://i216.photobucket.com/albums/cc122/loggskidder/221.jpg
http://i216.photobucket.com/albums/cc122/loggskidder/220.jpg
If I have just 820lbs left of pin weight, what is just an estimate of the load that I can haul??
Typically, most pin weights run 10-20%. If you run a 10% PIN weight, you can haul 8,200 lbs. If you run 15% PIN weight 6,150lbs. If you run 20% PIN weight you can haul 4,100lbs.
If you remove your 60lb spare tire & rim and put it on the trailer, now you have 880lbs of PIN weight. Now you can haul another 240-540lbs. :)
Hope your cargo is light & bulky. That's one scary big trailer for a 3/4 ton truck.
/ Trailer towing advice needed #43
That is a big AZZ trailer. The truck looks much better with the new mirrors. The 820# on the pin weight is going to be the problem unless you load it very carefully. As for the max weight, you need to look up your max GCVWR and subtract your total empty weight and that is your answer. I believe its around 22,000# but cant find it right now. Example is if your GCVWR is 22,000# and your empty weight is 15,780# then you are only left with 6,520# for cargo. Not much due to the weight of the trailer and its a 2500HD. You would barley be able to tow another truck like yours on that trailer.
Chris
/ Trailer towing advice needed #44
I am not sure but I believe the GM 3/4's have a 22,000# GCVWR so with the weight of that trailer he is not going to leave much for cargo, just over 6K. I don't have the info in front of me so I am sure you can correct me on the GCVWR on the 2500HD.
Just did some more math, I went to public skooool, so bear with me. It looks like your truck weighs about 5,720# so that means that trailer weighs 10,060#, or 3/4 of your available tow capacity. You need a shorter lighter trailer or a bigger truck. I will admit I have no clue what motorcycles weigh but I would guess small ones 400# and big ones 1000# so it all depends on what you are hauling.
Chris
/ Trailer towing advice needed #45
If Builders math is right then you should be fine with 7k worth of motorcycles.
/ Trailer towing advice needed #46
I still thing the limiting factor is the GCVWR of the 2500HD being at 22,000#. If you subtract the weight of the truck and trailer that only leaves you with 6,520# of cargo capacity. That cargo will include anything on the trailer or in the truck. Even things like chains and binders will take away from that.
Chris
/ Trailer towing advice needed #47
Chris
WIthout the actual weight of the truck we are just guessing anyway.
But 6500lbs or 7k is still a few motorcycles he can haul.
/ Trailer towing advice needed #48
Chris
I also have a 2500HD. I believe my empty truck weight is 6600 lb. GCWR is 22,000. Mine has 4 wheel drive and the Duramax w/ Allison. A two wheel drive w/ diesel may weigh less.
/ Trailer towing advice needed #49
I went to GM's web site and they listed the empty weight, no gas or driver, as 5,720# for a 2 wheel drive extended cab diesel. I am sure that is the base truck and really more around 6,000#. Either way he would be better off with a trailer that weighs half as much as that monster at over 10,000# empty.
Chris
/ Trailer towing advice needed #50
I agree that trailer is huge. Must have got a good deal on it. I think as long as he limits his load he'll be OK. He can haul a lot of motorcycles on a trailer that long.
/ Trailer towing advice needed #51
Chris
Chris
Who follows the numbers in the brochures? You don't because you always talk about towing way beyond your GCWR, too.
The guy seems grown up enough to buy/own the trailer he wants.
Besides, maybe is cargo is light or light & bulky.
/ Trailer towing advice needed #52
I know this. I am just trying to keep him legal. Like you said he is a big boy and can do as he wants.
Chris
/ Trailer towing advice needed #53
We all know there are only two numbers that only count.
GVWR
GCWR
Both are limits that we are not suppose to exceed on a regular basis or at all if it can be helped.
We realize the trailer is heavy, but it suits our needs great for what we do with it. It may be a little overkill though. We have pulled the trailer over a year with the dodge dually. We run DOT numbers and hit all the weigh stations. I just want to be legal and not get sited when I go thru the station. We haul dirtbikes and ATV's on it. I know you guy's may be kind of lost on that type of cargo, but our heaviest load weighed just under 26,000#. Not sure what the dodge weighs but we had 20 bikes and 11 atvs on it. On average 20 bikes weighs 4600# and 11 atv's weigh 4400#. If I am overweight on the GCVWR I'm afraid I'll get sited. Thanks for all the input guy's I now understand what GVWR and GCVWR and other terms stand for and how they work.
/ Trailer towing advice needed #55
Giving you the info to keep you legal is my only concern here. What you do after that is your own thing. I tow overweight and take a risk all the time and know that. I just wanted to make sure what you know what you were able to do legally. With the 6,500# or so left for cargo in your setup you will be fine for hauling the bike loads you are talking about most of the time. If you must haul a heavier load just use the dually.
Glad we could help you get the terms strait. That is one heck of a trailer. I would love to have it around my boat yard to move flat bottom house boats in and out of the drink. We are currently using a 60' house trailer frame with 5 axles and its on its last leg.
Chris
/ Trailer towing advice needed #56
Nothing wrong with that! I don't know many members here who don't own 3X the truck, tractor or trailer they need. ;)
Just keep the load off the front of the trailer to keep your PIN weight ~10-15%. However, don't "rear load" it too much, you'll have a loss of control. :eek:
I think a set of Firestone airbags would do you a lot of good. Remember, you have the same basic drivetrain as a 3500DRW, just lighter springs and less tire capacity. Although air bags won't make you legally able to carry more, they will make your load more stable, they'll make up for the shortcomings of light springs. A set of quality, stiff, load range E tires would give you the same tire capacity as a 1-ton SRW.
Hey guy's been awhile since I posted. Just wanted you guys to know that I pulled the trailer once to cincinatti but didnt get a very big load. Truck did good. The bad news is Thursday I was headed to Atlanta nad went thru the weigh station and was pulled in to have a truck inspection done. They pulled me inside and said I need a Class A cdl to pull the trailer because the GCWR is 30200. They did not write a ticket but made me unhook the trailer and leave it until a CDL driver had to come get it.
/ Trailer towing advice needed #58
Sorry to hear about your woes. Once you hit that 26,001 threshold you are open for trouble since you are doing this for a business. Glad to hear they just made you drop the trailer and no ticket.
Chris
/ Trailer towing advice needed #59
Eventually that will happen to everyone who has a truck & trailer over 26,001.
I've been trying to remind all the guys here who tow way beyond their truck's payload safety limits of that.
It was just a matter of time, but hopefully you'll get your class A CDL and get all this behind you. Then you can be legal over the road and properly trained.
/ Trailer towing advice needed #60
Don't he still have another problem here being that the GVWR's add up to 30,200#, way beyond his 22,000# GCWR of the 2500HD truck? It may just be a matter of time that he will get called on that one.
Chris
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2022 EZ-GO ELITE...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
