Trailer Too Short?
/ Trailer Too Short? #21
There is a post under "build it" I believe, that shows a guy that figured out a way to attach a hitch ball to his backhoe near where the bucket would be. The hitch weight on a trailer is about 10% of the GVW. With the ball-on-a-hoe he was able to lift up the whole front end of the trailer and dump it out. He posted a picture of this. Pretty cool idea that would work to a point. You will be limited by the lifting capacity of the hoe.
If you need a short trailer for convenience then look at a gooseneck. They offer better load distribution and maneuverability. The area above the hitch offers a place to set your bucket so you need less length behind the truck.
Also figure a 7000 GVWR trailer will weigh a couple of thousand lbs. Leaving you with 5k, is that enough?
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2012 DOOSAN G25KW GENERATOR (A60736)
2012 DOOSAN G25KW...
2020 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2020 DRAGON 150...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
