Trailer to pull with a bike
   / Trailer to pull with a bike #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I have this idea to build a trailer to pull with my bike - for small local shopping and such. Already have two mountain bike wheels - they were free from the landfill. No for the frame, I see two ways to build it (I don't feel like making it wooden):
- weld it from square tubing say 1/2x1/2"; the standard, just like my big trailer, onluy scaled down and light
- use 1/2" steel conduit and tubing bender, bent pieces welded together. I dont know if there are any issues with welding conduit except the galvanization.
Any other idea? I considered plastic conduit, since it is used for soccer goals and such, but I dont trust it too much.
The trailer should carry 100 - 200 pounds, depends on situation and distance.
Thanks for any ideas
   / Trailer to pull with a bike #3
Remember that, just like any other trailer, stopping is more important than pulling!
Mike
   / Trailer to pull with a bike #4
For weight considerations, maybe try your hand at fiberglas? Not that hard once you get the basics down. Hopefully your talking about pulling them with a bicycle, not a motorbike, as the mountain bike wheels probably won't hold up to the speeds of a motorbike.
David from jax
   / Trailer to pull with a bike #5
When my son was 10 I made a sidecar for his BMX bicycle out of EMT with a flat 10 gauge aluminum deck. was tricky welding with a stick welder but it outlasted him & the kid he later sold it to. It would carry my 200 lbs. MikeD74t
   / Trailer to pull with a bike #7
Oh oh, did the traffic ticket mature?:confused::confused:
Do some Googling. There are different styles of trailers. Use the lightest tubing possible as hills build character.:D:D Also stop in at a bike shop and look at some.:D:D
It will also help to switch to dehydrated beer if you can find a reliable source of sufficient quality!;)
Mountain Bike tires will survive at some pretty good speeds.:p
   / Trailer to pull with a bike #8
You are talking about a bicycle I beleive, so in that case have you considered getting a radio flyer wagon and taking the front wheels and steering hardware out of the front and adding two peices of tubing or angle from the front of the wagon and extend out to hook up to the bicycle?
   / Trailer to pull with a bike #9
Without a coupling capable of turning, such as a trailer hitch, this method would cause steering problems when trying to turn as either the back wheel or trailer wheels would have to slide when turning.
CATERPILLAR D11T HI TRACK CRAWLER DOZER (A52705)
CATERPILLAR D11T...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2018 JLG 3246ES 32ft Electric Scissor Lift (A53421)
2018 JLG 3246ES...
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
