Trailer Stake Pocket Tie Downs
   / Trailer Stake Pocket Tie Downs #1
kday64
South Eastern Connecticut
Kubota BX2360
All,
I managed to break an ATV ratchet strap this weekend and now I am looking for a long term reliable solution.
I was using the ratchet strap looped through a stake pocket. The strap was not flat and smooth. It was pulled into corner if the pocket because of how my BX2360 was positioned for weight distribution.
Bottom line is I want to build a stake pocket insert 1.5x3.5x4" with a 2x4x3/8" top plate welded on top. On top of the top plate I then want to weld a D Shackle.
To keep the insert in the pocket while under load I want to put a 1/2x5" pin through a series of well aligned 9/16" holes.
Bottom line I have no idea where I can cy 1.5x3.5" steel tubing. Any thoughts?
~Kevin
   / Trailer Stake Pocket Tie Downs #2
They make the very thing you want to build. Sells for about $20 a pop with the pin. You can not build them for that.
Chris
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A53426)
2023 MAXEY G8X...
2017 John Deere 30G Mini Excavator (A51691)
2017 John Deere...
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
1267 (A50490)
1267 (A50490)
