Trailer Stake Pocket Tie Downs
/ Trailer Stake Pocket Tie Downs #1
kday64
Gold Member
South Eastern Connecticut
Kubota BX2360
All,
I managed to break an ATV ratchet strap this weekend and now I am looking for a long term reliable solution.
I was using the ratchet strap looped through a stake pocket. The strap was not flat and smooth. It was pulled into corner if the pocket because of how my BX2360 was positioned for weight distribution.
Bottom line is I want to build a stake pocket insert 1.5x3.5x4" with a 2x4x3/8" top plate welded on top. On top of the top plate I then want to weld a D Shackle.
To keep the insert in the pocket while under load I want to put a 1/2x5" pin through a series of well aligned 9/16" holes.
Bottom line I have no idea where I can cy 1.5x3.5" steel tubing. Any thoughts?
~Kevin
/ Trailer Stake Pocket Tie Downs #2
They make the very thing you want to build. Sells for about $20 a pop with the pin. You can not build them for that.
Chris
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2010 Volkswagen GTI Passenger Car, VIN # WVWFV7AJ7AW231214 (A61569)
2010 Volkswagen...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
2025 QSJ Hydraulic Sweeper Mini Skid Steer Attachment (A61567)
2025 QSJ Hydraulic...
1018 (A61165)
1018 (A61165)
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
