Trailer Size for a 2710
/ Trailer Size for a 2710 #1
Anonymous Poster
Epic Contributor
I will be buying a B2710 soon and was wondering what size trailer that I need, that is lenght wise. I assume a 6' would be wide enough. Just need to know how long a B2710 plus implent would be. I would like the trailer to be as short as possible. Thanks in advance!
/ Trailer Size for a 2710 #2
DSMITH,
I can't answer your question, but you might also want to post if you'll have a front end loader and what kind of implement on the back. Different rear implements stick out further. /w3tcompact/icons/smile.gif
Good Luck, JimBinMI
We boys and our toys!
/ Trailer Size for a 2710 #3
I don't know much about the 2710, but Carvers is selling a 2710 and trailer. I would think you would need a min. of a 10,000 lb trailer when you add up implement weights with the tractor. Rat...
/ Trailer Size for a 2710 #4
Search this site and the archives for "trailer" and you will see a lot has been written on the subject as well as the towing vehicle and brakes on the trailer.
Trailer brakes are essential. Any trailer to haul a tractor will require a frame mounted heavy duty hitch with solid steel receiver and 2 5/16 ball, 10 or 12,000 pound tandem axles, side and front rails, 8 to 8 1/2 feet in width depending on tractor tire spacing and implements to carry. A six foot box blade on the rear of the tractor probably needs a maximum width trailer. Length of mine is 18 feet and a mower hangs out the back with tractor and loader. Cost for a decent quality trailer suitable for pulling a trailer is less than $2000 and will weigh about 2000#. The ramps need to be heavy duty and store on or under the trailer. A break away switch is required by law as are side and end reflective markings. Do not accept a trailer that has a 2 inch ball as they can not be rated 7500# GVW or above although they are regularly sold (without nameplate ratings).
I believe on the http://www.carverequipment.com site there is an article on the perfect trailer for a tractor that would make interesting reading for you.
/ Trailer Size for a 2710 #5
I wouldn't disagree with any of the other responses, but I haul my B2710, with front end loader, only occasionally and for relatively short distances in an area with practically no traffic and I use a 6' x 16' trailer (of course, that's the trailer bed dimensions - inside the rails, and I only have 5' implements). The tail wheel on the brush hog sticks out behind the trailer if I have the front end loader on; the other implements will fit entirely on the trailer. In other words, I'd say a 16' would be the minimum you can get by with; an 18' would be better, but I had this trailer before I got the tractor.
Bird
/ Trailer Size for a 2710 #6
Like bird I use a 16 Ft. trailer to tow my B8200 (about the same size as a B2710) behind my jeep GC with no problems. I would not want to do this every day but the once or twice a month works well for me. The loader and rotory cutter do make it about a ft. short but I haven't had any problems with it.
Von
I use an 18-foot trailer, my 2710 has a loader and backhoe. It really lounges out nice on the 18 footer. I think a 16' may be cramped for a 2710 with backhoe. My haul commute averages 2-3 times weekly. I use a Hudson Bros. tandem axle trailer with electric brakes. I am setup with a Class IV trailer hitch, 2 5/16" ball, solid 2" ball mount, and breakaway kit on the trailer, of course a cab mounted brake control unit also.
/ Trailer Size for a 2710 #8
I have 6.5'x16' trailer with dual 3500lb axles (electric brakes on one axle) that I haul my B2150 on (the B2150 is also about the same size or slightly smaller than the B2710). With loader installed, my rotary mower overhangs about 2 feet.
Since you addressed mowing in another post, I'll add this in:
A friend of mine had a problem getting his 5' LandPride side discharge 3pt mower on my 6.5' wide trailer because of the side discharge chute. I am currently looking at rear discharge finish mowers; I know that a 5' will fit easily and I may even get a 6 footer on the trailer (the 72" LandPride model has an overall width of 74").
I guess I should have mentioned that I am limited by a 1994 Nissan King Cab 4X4 V6. So I would need the smallest trailer available. Thanks...
/ Trailer Size for a 2710 #10
Drive slow.
You should check the manufacturer's towing recommendations for your vehicle, but it will likely be marginal to tow a tractor, loader, and implement on a trailer. This towing recommendation is normally listed in the owners manual. My Jeep Cherokee is rated at 5000# and that is with an equilizing type hitch and frame mounted receiver with brake controller and trailer brakes. A tandem wood floored trailer will be close to 2000#. There are lightweight trailers, but they are pretty expensive because they use a lot of aluminum.
2021 CAM P5714FTT 14ft. 10000lb Tilt Trailer (A64047)
2021 CAM P5714FTT...
2014 John Deere Z930M Zero Turn (A63116)
2014 John Deere...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
2022 Polaris 1000 Ranger (A64047)
2022 Polaris 1000...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
2018 FREIGHTLINER CASCADIA CA125 DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
