trailer rebuild
/ trailer rebuild #1
bob2449
bath pa
jdx585
well its time to rebuild the trailer. took about 3 days took it apart bolt by bolt . 0114151625.jpg0114151626.jpg0114151626a.jpg0114151627a.jpg0116151616b.jpg0117151504.jpg0117151504b.jpg0117151504.jpg
/ trailer rebuild #2
Looks like a new trailer. Is that pressure treated lumber on the bed & side boards??
/ trailer rebuild
yes it is pressure treated . the first for lasted 12 years. not to bad.but it need new paint it was red now its jd green . it is a northern tool trailer 2003 good for 2 ton. thanks for the replys.
/ trailer rebuild
ridem hard and putem away wet
/ trailer rebuild
thanks for the great job.
/ trailer rebuild
also di a cab re build got the fram and thr roof. had to build the rest.built doors and plxe for the rest. windshield buy new. wipers 1999 dodge duringo rear gate. heater also from 1999 dodge celing air coil works great.BOB - 1208141631.jpg1214140556.jpg1122140507.jpg1214141558.jpgDSC04221.jpgDSC04221.jpg:cool2:
/ trailer rebuild #8
The build looks good, but the pics must be cell phone wannabe pics. Would be nice to see them clear and clean for seeing the detail that you built into your work.
/ trailer rebuild
may this will be better. cant take them out side freezing rain.DSC04259.JPGDSC04260.JPGDSC04263.JPGDSC04274.JPGDSC04273.JPGDSC04272.JPGDSC04269.JPGDSC04269.JPGDSC04268.JPGDSC04266.JPGDSC04261.JPG
/ trailer rebuild
just heat I have to cut a hole in the hode for the comperser not good . the heater fan will just fine. with the windows off.
/ trailer rebuild
tractor and trailer take a lot of space 19 ft long shop is only 30 by 30 so take from there lots of stuf
/ trailer rebuild
well I was out in the shop took new pic. just to make you happy. did you fall asleep
/ trailer rebuild #16
That's nice. Loaded, I'd bet it might be dangerous to pull with a lightweight tractor.
/ trailer rebuild
hi gittyup. yes it is dangerous the x585 can pull but you cant stop if its to heavy . don't go down hill to heavy.0117151504a.jpg
/ trailer rebuild
yea this old man needs sleep to:newhere:
KILLBROS GRAVITY FLOW WAGON (A64277)
KILLBROS GRAVITY...
2013 F150 Crew Cab 4x4 (A62613)
2013 F150 Crew Cab...
2016 KENWORTH  W900 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH...
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
2022 EZ-GO ELITE...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
