Trailer Ramps
/ Trailer Ramps #21
Whatcha talking bout Willis?
Brett
Brett,do you be same one wut ussua have a 6 leaker foewd and possing on Fordtruckenthusiasts? I found more information on that forum I could use than others all put togeather. :drink:
/ Trailer Ramps #22
I just got a 6.0 around the first of the year. Had a 17 450 and 13 250 then add in some 5.9s, 6.2s, 6.6, 7.3 and a couple 6.7s.
There’s someone else that has a similar screen name to me with the “e” and “l” swapped
Brett
/ Trailer Ramps #23
Because I gave $1600 for this 20ft deck over. I’m not like rustyford guy, not made of money lol. Thus my name
Ok that is perfectly understandable. But....if money was the same would you rather have a tilt or the one you have now?
Serious question. I'm looking for the pros and cons on a tilt vs ramps.
TBS
/ Trailer Ramps #24
TBS
If money was the same I’d still rather have my Big Tex with mega ramps over a tilt trailer. No good way load stuff on the trailer and then load the machine. If you spent some of that money I saved and put hydraulics on the ramps I’m not sure what advantage the tilt trailer has anymore. With that being said I’m looking for a light duty tilt trailer to haul my side by side, Grasshopper, and tractor. 1 at a time obviously. Since tilt trailers are expensive I’ll probably end up with another ramp trailer.
/ Trailer Ramps #25
TBS
If the money was the same,I'd go for a rollback tow truck. But the money isn't the same for a tilt trailer nor rollback wrecker when compared to a trailer with ramps. With all that out of the way,time is money and tilt trailers and rollbacks pay for themselves when used all day every day. Neither a tilt nor rollback make's sense when it sit's idle 99% of the time. If you go back to my first post,you'll notice I have to improvise once in a while but the majority of my hauling is best served by ladder ramps so that's what I have.
/ Trailer Ramps #26
Funny you should be needing a trailer that tilt's to haul those things. I've been building just such trailer to haul a SxS,zero turn,Cub 154 Lo-Boy and a single round bale. I started with a tilt boat trailer with a 2k axle but 4 hole 12" wheels. I installed 5 lug hubs and 16" wheels to gain tire carrying capacity that equal's axle rating. I cut about 3' off tongue,turned winch pedestal around so that it slant's toward rear. Installed better winch to pull front of loaded trailer up to full tilt (about 20*) or drag things up onto trailer. Once trailer is tilted (by hand if empty,by winch if loaded) the same 5/16 grade 5 pin that secure's tongue in transport position hold's it at tilt so winch can be used to pull things on or lower off trailer. I haven't desighned ramp but it will only need to be be about 18". 2 x 3 x 1/4 angle bolted across boat trailer frame where it narrow's to 11" at front is main support for deck. You or someone might find something they can use if into diy. I also told folks about it for another reason. Some of the loafers who came by said they would make it heavier duty so it could be more versatile. My usual response was "I'm making it flimsy so people will be afraid to borrow it." I already have a bumper pull trailer but I wanted something that can be moved around by hand and pulled with a suv or lite truck. I also have a 22' deckover fifth wheelxgoose neck that grandkids don't have hitches for.
/ Trailer Ramps #27
As in light duty I need tandem 3500 pound axels. That’s about the minimum to haul the tractor and trailer itself.
/ Trailer Ramps #28
I checked out some Diamond C tilt trailers in Seguin at D&D a couple weeks ago. None of this is an issue with a tilt trailer. Making a tilt look better all the time.
TBS
I can't see any good reason to buy a tilt. Sure, they're great, when they work. I used a PJ gooseneck tilt that decided not to stay tilted or locked after driving 100 miles to pick up a motorhome. We made do with redneck ingenuity, but it added several frustrating hours to our day. I prefer the "ladder ramps" as they are more versatile. Want to load a bunch of UTV's? Mount the ramps on the sides instead of the rear. Always use dropleg stands or independent stands, on the rear, to keep the ball from shearing. Remember, the load will weigh the trailer down, don't pin the stands at the top, give it an inch, or two, depending on the weight of the load.
/ Trailer Ramps #29
I prefer the hinged ramps over the loose ramps that you have to put in the side. The spring loaded hinged ramps are fast and trouble free. The loose ramps are a pain and become an impractical option as the capacity increases.
/ Trailer Ramps #30
TBS
I have never used a tilt trailer. I have used landscape trailers, equipment trailers and my deck over trailer.
I like my deck over a lot, I like the ramp I had built a whole lot. I’m happy with that trailer except for the brakes, something I have to work on yet.
It’s all about what people need to haul, like tractors there is not a one style fits all trailer.
I don’t care for how steep the climb is to the top of my deck over, it hasn’t been a issue yet but my gate is all one piece, no need to worry about having ramps lined up etc but that gate can’t be bought on a new trailer. I would imagine a tilt trailer would have similar benefits because you drive up a solid deck, that would be a plus if you plan to load things that are wider than one another.
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2006 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2006 BIG TEX 20...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Attention (A57148)
Attention (A57148)
2005 Honda Accord LX Sedan (A59231)
2005 Honda Accord...
