trailer plow
/ trailer plow #1
jpm
Platinum Member
Redbud.southern vt
4110 mahindra
i was driving a round yesterday and saw a 3pt 3 plow for sale on the side of the roadand stopped but it was a cat 2 pins.talking to the owner and he said he had a 2 plow trailer type.has any one use one or both types?
/ trailer plow #2
new pins are 8 bucks each.
/ trailer plow #3
A TRUE CAT II plow will have a LONGER drawbar, with CAST (or forged) ends. SOMETIMES, one end is replaceable. (i.e. Ford model 101 plow) . In the case of older John Deere CAT II plows, the top link "mast" is different (taller) on CAT II plows. It isn't always a simple matter of changing lower link pins.
/ trailer plow #4
Another thing to consider is that sometimes folks put Cat II pins on Cat I implements. My JD LX-6 mower had Cat II pins on it when I bought it used.
/ trailer plow
thanks for the reply's.it popped up in my mind just change the cat 2 pins after
i posted. i'm still interested in how well the trailer type works? that part i did not make that clear in my original post i realized after rereading it thanks j
/ trailer plow #7
A trailer plow will work but you need a high weight to HP ratio for the tractor to have sufficient traction. For example, I plow with a 4500lb 20hp tractor pulling a 2-14" trailer plow. The tractor barely has enough weight to maintain traction. remember that a 3 pt plow puts draft onto the tractor thus increasing traction and it is MUCH more manuverable than a trailer plow. It is very difficult to impossible to back up with most trailer plows so they are not a good choice for tight spaces. Is the trailer plow that you are looking at hydraulic lift or rope trip?
/ trailer plow #8
Good answer!
/ trailer plow #10
In the agricultural area in which I grew up trailer plows were the norm. There were very few three point plows in use. Backing really was not a problem as the fields were large.
From the little I have seen I would prefer the trailer type plow over the three point if there was significant acreage involved.:)
RoGator RG1100C (A63688)
RoGator RG1100C...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
