Trailer Options
/ Trailer Options #1
workhorse
Bronze Member
Has anyone used a two-place snowmobile type trailer to haul their Utility Vehicle around? If so, does it work well, or do you get nervous when you think about hitting the freeway?
/ Trailer Options #2
I have on several occasions. It towed perfectly OK, but it was a very tight fit, in fact it hung out over the back a tad. I used it with my Rhino 660 and drove over 125 miles without any problem and it rode just like it were a snowmobile. The tongue weight was just right and again with no problems.
The Gotcha Man :)
/ Trailer Options
Thank you. That gives me more confidence that I can get double duty out of a sled trailer.
/ Trailer Options #4
I would check the GVWR of your trailer and remember this includes the weight of the trailer also. Most 2 place snowmobile trailers are 1000 to 1300 lbs. I am not able to say what the Rhino 660 weighs but my XUV gater is over 1300 lbs.
1998 GMC SIERRA 1500 (A67714)
1998 GMC SIERRA...
2012 MACK GRANITE-GU713 (INOPERABLE) (A67714)
2012 MACK...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
2022 John Deere 450K LGP Crawler Tractor Dozer (A66734)
2022 John Deere...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
MAGNUM TRANSFER PUMP (A67714)
MAGNUM TRANSFER...
