Trailer lights
/ Trailer lights #1
northcreek2624
Lake View,N.Y.(WNY)
KIOTI DK40(2002)) Jacobsen 628D AWD Turfcat
Maybe "misterkioti" or someone else might know if there is harness(pt.#)that would plug into the empty female jack at the rear which I could then wire to an outlet of my choice.
It's not shown in my parts book and I didn't check with my dealer.
The empty jack I'm refering to is just a round plastic connector near the right rear tail light.........Thanks,Mike
/ Trailer lights #2
Mike, O'Bryans told me that there wasn't any plugs that matched the configs of that on the back of the Kioti.
Jeff
/ Trailer lights #3
Yea! Glad you asked. I want to run some lights off the plug but couldn't find a match. I just used those splices on the wires. Maybe misterkioti will know?
/ Trailer lights #4
Mike, I was told by the service manager where I bought my tractor that the plug was there as a carryover from the tractors produced for local consumption in Korea. He said that the farmers and other users there used the tractor as an auxiliary power source in the outlying areas there. As with many "facts" I don't know that this is true but it sounds possible.
/ Trailer lights
Farmhouse,I'm thinking that I saw a trailer outlet factory installed on the back of a DK45.I was hoping that it used the same connector as the 40.No big deal I'll just cut the plug off and splice..........Mike
/ Trailer lights #6
Hi
Those eletrical plugs on the rear are the only plugs we have in this country (australia) that i am aware of, commonly called 5 or 7 pin trailer plugs. But surely if they are not common in the states the dealers or Daedong USA would change them with no charge.
vin
/ Trailer lights #7
I looked this afternoon and did not find anything in the parts books.
Try this.
Remove the old plug, strip the wires and replace the plug with one that is available to you from a local autoparts.
Just an idea.
K
Quick Hitch Mini Excavator Attachment (A61572)
Quick Hitch Mini...
2018 FREIGHTLINER CASCADIA SLEEPER TANDEM AXLE  6X4 TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
JOHN DEERE 310D BACKHOE (A63290)
JOHN DEERE 310D...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
