Trailer Jacks
/ Trailer Jacks #1
maltpj
Jacksonville, Fl
John Deere 5105 4WD
tj6.jpgThis wasn't my idea, but it's a good one so I used it.:D
The jacks were $20 a piece at Harbor Freight.
I welded the mounts that came with them to a small piece of plate and bolted them on.
Now the rear of my truck stays on the ground when I load it up!
/ Trailer Jacks #2
Great idea, hello from a neighbor in Orange Park, Don't forget to raise them, that is the biggest killer of those and the front jacks
Be careful and you will be fine
Jim
/ Trailer Jacks #3
Awesome idea and great pics!
I want to do exactly the same, but my trailer is aluminum. Do I need to put something between the steel plate and the aluminum frame to prevent galvanic corrosion, or does it matter?
If you can weld, could you not have welded the circular mounting flange directly to the trailer instead of to the steel plate? Any benefit to using the bolt on steel plate vs directly welding?
/ Trailer Jacks #4
He might be like me- I can weld fairly well on something flat, but trying to weld vertically and upside down is very hard to do well:p
/ Trailer Jacks
Yes what he said.
If you painted the plate and you used stainless hardware it would probably be OK.
/ Trailer Jacks #6
maltpj said:
Yes what he said.
Aluminum will always loose where dissimular metals are concerned...painted or not. Sealing it to keep the water out is the best preventative.
/ Trailer Jacks #7
If I did exactly what Maltpj did, but on my aluminum trailer, how would I seal it against water? You mean run a bead of silicone around the edge of the steel plate? Anything else?
/ Trailer Jacks #8
Simple solution if the disimilar metal corrosion is a problem- place a thin aluminum sheet metal "shim" between the aluminum trailer and the steel jack mounting plate. That way if corrosion happens it is on the thin shim, which is easily replaced after a few years.....might even be able to cut it out of a beer can...
/ Trailer Jacks #9
Apply sealant to the entire plate then bolt it to the aluminum, apply enough so you get squeez out then just run your finger around the edge to make a clean edge...water will not have a place to enter.
/ Trailer Jacks #11
i see broken or bent jack handles in the future, better make sure you secure them in the up position. I have seen that kind of set up on travel trailers many times but they use screw jacks mounted under the trailer.
good lookin job man
/ Trailer Jacks #12
If you painted the plate and you used stainless hardware it would probably be OK.[/QUOTE]
Don't use Stainless hardware it is pretty soft. I would hate to have those bolts shear off when your driving up the ramp and the nose of the tractor dive down. Use only grade 8 bolts for that kind of weight.
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
240 Massey Ferguson Tractor (A61165)
240 Massey...
2008 CATERPILLAR D4K XL CRAWLER DOZER (A64279)
2008 CATERPILLAR...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
2019 Polaris Ranger Crew XP1000 4x4 Utility Cart (A61572)
2019 Polaris...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
