Trailer hitch
/ Trailer hitch #1
Garrett
ne ohio
Does anyone make an adaptor for a lawn tractor that would let you connect a small trailer (ball hitch)? /forums/images/graemlins/cool.gif
/ Trailer hitch #2
Just buy the the short trailer "ball mount" (that slides into the receiver), and bolt it to the tractor. It's what I do.
/ Trailer hitch #3
i had the same issue. i got a piece of flat iron 1/4"x1/2"x6" i drilled two holes next to each other (at one end) and attached them to the tractor, then one hole on the other side to for the ball... it works well. and it took 15 mins and cost less than $5...
/ Trailer hitch #4
</font><font color="blue" class="small">( i had the same issue. i got a piece of flat iron 1/4"x1/2"x6" i drilled two holes next to each other (at one end) and attached them to the tractor, then one hole on the other side for the ball... it works well. and it took 15 mins and cost less than $5... )</font>
I did the same thing with a flat 1/4x 2 by 7'' long flat piece of scrap steel that I had just laying around? Didn't cost me anything. I had to drill holes in 2 different locations on the tractor end of the adapter so that it would fit on either my Bolens or power craft tractor.
It's quick and easy to install or remove so I can switch from pulling a trailer with a hitch pin type tongue to a trailer with a ball type hitch in 2 minutes or less.
I'm not sure it works cause all I've got to go on is my experience with it which don't tell me nothin.
/ Trailer hitch #5
</font><font color="blueclass=small">( i had the same issue. i got a piece of flat iron 1/4"x1/2"x6" i drilled two holes next to each other (at one end) and attached them to the tractor, then one hole on the other side to for the ball... . and it took 15 mins and cost less than $5... <font color="red">it works well </font> )</font>
<font color="red">
How do you know it does when all you have is your actual experience with it? </font>
/ Trailer hitch #6
Here's what we do:
Buy an 18 inch square receiver tube (Northern, Hab. Frt. or TSC)
Buy ball mounts at the heights you need them
We use it with vise mount plates sometimes if we need to hold things for repair or cutting in the feild.
Also, we put an extension on one and added a light mesh carrier for tools. Works great, alot nicer than towing a cart around /forums/images/graemlins/grin.gif
/ Trailer hitch #7
im sorry for not being clear.., it was .25x1x6 i it worked on my murray... it was not half an inch wide... there is no way that could make it... wish i was some help...
AMERICAN 14 T/A DOG HOUSE (A63569)
AMERICAN 14 T/A...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2015 John Deere R4038 Sprayer (A63109)
2015 John Deere...
Worksaver Terra Max Ripper (A64047)
Worksaver Terra...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59910)
2016 FREIGHTLINER...
