Quick Hitches Trailer hitch and top link bushing?
   / Trailer hitch and top link bushing? #1
All In A Days Work
Chelan, WA.
Kubota L4701, Land Pride RB3784 Rear Blade, Bearcat SC5540 Chipper Shredder
I am building a 3-point trailer hitch out of scrap iron that laying around. The main 2" receiver part I picked up at a metal drive I was part of years ago.
Anyway I am building it to attach to a quick hitch and I am looking for a bushing to go from 3/4" inside to 1 1/4" outside 2" long. Any idea where I can buy one? I don't have a 1" drill bit or I could drill out the bottom hole and use a Cat 2 to Cat 3 bushing.
   / Trailer hitch and top link bushing? #2
My local steel supplier lists a DOM tubing that's exactly that size. 1.25 od and .75 id. Presumably other suppliers can get it also.
Thanks, I will call tomorrow.
I thought about doing two bushings a Cat 1 to Cat 2 and then a Cat 2 to Cat 3 but nobody locally has that setup either. The local parts store could order but over $15 bucks for the pair, forget that! A place called Agri Supply has them for under a buck each.
   / Trailer hitch and top link bushing? #4
I use cat 1 to cat 2 and cat 2 to cat 3 bushings on most of my implements. Your tractor dealer or a farm store should have the bushings.
   / Trailer hitch and top link bushing? #5
Fleet farm is where I get mine at if you have one close by.
   / Trailer hitch and top link bushing? #6
McMaster has .75 I.D. 1.25 O.D. tubing for like $23/ft.
I buy the 1-2 and 2-3 at Tractor supply for like $4-5 total. Falls into the *whatever* category.
   / Trailer hitch and top link bushing? #7
Those may not be 2" long, more like 1.75"
   / Trailer hitch and top link bushing? #8
The ones on agrisupply say 2" long. I assume they are all the same.
Believe it or not I have checked with both tractor dealers, parts houses, farm stores, bearing supply and two hardware stores. I found the cat 1 to cat 2 in the hardware store in town. The problem is the 2"length, I should have made it 1.75. The local farm store (50 miles away) has both in the 1.75" length. I'm going to use a couple of washers for now, to narrow the gap. I copied the design of my Landpride rear blade instead of doing a little more research. I have to chock it up to inexperience in fabricating.
By the way I priced the shipping from Argi Supply, $13.94 UPS. Maybe half that for usps.
No DOM tubing that size in the area.
I got it done all it needs is paint now. I found the 2" top link bushings at a farm store, geeze. Anyway my first tractor project is almost done. Now for a ballast box.
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
RYOBI CHAIN SAW (A51243)
RYOBI CHAIN SAW...
CLASS ROLLANT 160 HAY BALER (A51243)
CLASS ROLLANT 160...
