Trailer frame sizing
   / Trailer frame sizing #11
I built a 5x8 dump trailer recently for the exact same purposes as you are intending to build one. I bought a set of plans and the plans specified C4 5.4 channel for the frame and 2x4 11ga tubing for the bed and cross rails. They were engineered drawings and I compared it to lots of other similarly sized dump trailers and it was about the same. I ended up putting more bracing on the frame than the plans just in case.
Using the axle placement suggested by the drawings, I ended up with lots of tongue weight (at least more than I can lift when it's empty). The hydraulic cylinder plus the power unit adds 200lb on there.
One disadvantage to a single axle setup (which I have) is that the trailer's frame/axle capacity will likely exceed the tire's payload. Maybe implement tires could be used rather than trailer tires.
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
5' MOWER (A52706)
5' MOWER (A52706)
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
2016 Ford F-350 (A56858)
2016 Ford F-350...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
