Trailer decking
/ Trailer decking #21
Soundguy said:
Leaching from spills ont he soil are one of the largest factors.. however impregnated porous materials that come into contact with water ( rain for instance ), can cause leaching into the environment. Again... the drip from the cotter key under an old ford or massey ferguson likely introduces more oil directly into the environment thatn we are talking about from some incidental film lifting off of trailer decking.
If you want some reading that will put you to sleep about leaching characteristics of wood, hit the epa site and read the reams of data that led them to pull CCA treated lumber from kids playgrounds and picnic tables at publicly funded sites. A few PPM of arsenic showed up in the dirt around the playground... way under 'safe exposure' levels from what I understand.
I'm not criticizing your practice.. just saying that from a chemistry standpoint.. a porus substance like wood will allow chemical migration both ways.. even if it has a high affinity to keep the material entrained. One thing I should clarify. When i refer to leaching.. I'm not only refering to the hydrocarbons.. I'm also refering to the residual and trace heavy metals and other goodies you can find in waster oil.. lead, mercury among the largest.. etc. Whereas a hydrocarbon may stay entrained in the wood, the metals can migrate.. Even lead, in nature, can form lead sulfate.. etc Used oil can also contain halogenated compounds, and goodies like benzene from gasolene engines. emulsified coolant from trace leaks inside the engine can also show up.. these emulsions will likely leach out of the wood much easier thant he hydrocarbons. Any remaining VOC's won't hang around int he wood too long either.
As for bridge inspection.. We've got some overhead railroad bridges that, when viewed from the bottom.. look pretty scarry... exposed metal reinforcement in areas the prestressed concrete, or poured-in-place slabs have cracked over the years.
soundguy
Infinately small traces CAN be "lifted" as you mention. But, How much more/less is produced during the manufacturing process, transportation and delivery and final disposal of empty containers/application brush, ect, of the asphalt paint (petroleum based) you're suggesting? Also, the asphalt paint DOES break down in sunlight, will wear off in time, and probably has as much "environmental harm" contained in it as my motor oil, albiet not the SAME chemical make-up as the oil's "harm". Not mentioned as a "downer" on your suggestion, but as an example of how ANYTHING we do effects the environment in some shape or form. What we do as proper stewards of the earth is to MINIMIZE exposure to environmental damage. I'd contend my method probably doesn't adversly effect the environment any more, and possibly less than using an asphalt paint product or any other PETROLEUM based sealer. (ie, use the compounds we already have created rather than create additional NEW compounds, all the while still having to deal with those old products)
HOW WE DO WHAT WE DO is the key here. When I put the oil on the trailer deck, I do so in certain conditions. Cool, but not cold weather. That allows the oil to soak in without evaporating the diesel fuel in the mix. (rather than in hot sunlight) I always wait for 4 or 5 really dry days, with a few dry days to follow. That minimizes the moisture in the wood so as not to interfere with the oil's soaking into the wood, then to limit the possibility of it washing away until it's completely penetrated the wood.
In the final analysis, I'd much rather see my used oil on a trailer deck than what probably happens to a great deal of this nations used oils. Far safer my way than simply dumping it on the driveway like far too many people will do. By applying the oil/diesel mix in a safe, responsible manner, there's probably somewhere next to zero chance of it adding a measurable/detectable volume of contaminates to the soil, water or air. No more or less so than with any other product that could be used in it's place.
Being in the construction industry, in particular, working for a contractor that builds schools, hospitals, and government buildings, I've read file cabinets full of documents on CCA contamination. One of the most interesting stories I recall was from a Missouri beef cattle farmer who built a new deck on the back of his home. He took the scrap lumber to a sink hole in one of his pastures and burnt it. He later shoved a couple partial round bales of hay over the burn spot to cover it up. Some of his cattle ate the hay, cleaning it up clear to the ground. A few weeks later, he had dead cows. Extremely high concentrations of CCA was determined to be the cause of death. They got it from the ashes of the scrap lumber.
Again, ANYTHING we do effects the envirnoment in a negative way. Without resorting to Al Gore propaganda techniques, think of it in these terms. You're out on the road. You want something to drink. You pull into a gas station and buy a bottle of water. Most likely, that water is not much more (if anything at all more) than simple tap water. No environmental damage, huh? Guess again. What about that PLASTIC bottle? How much harm was done to make that bottle? How much pollution did it add the the air to get that bottle to the gas station? What about the CFC-based refridgeration system that kept that water cool? And where will that bottle end up when you're all done with it?
My point is, do anything SAFELY and RESPONSIBLY, you reduce the impact possibly to immeasurable levels. Do anything without considering the harm you may be doing and nothing is without environmental hazzard.
/ Trailer decking #22
Sure.. i agree... just about everything we do has an environmental impact.. most of it negative. some more than others.
And yes.. I imagine a lot of waste oil does not get used / recycled in a way that would be better for the environment.. Ie.. re-refined.. or at very least.. burned for fuel...
soundguy
/ Trailer decking #23
If you can find a local sawyer that has hemlock or tamarack it makes a great trailer deck without treatment. I have used it on wagon beds and it supports a lot of weight and lasts a long time even exposed to weather year round. Only issue is that in a lot of places even sawdust is now considered a form of toxic waste so finding a local sawmill may be hard:eek:. It also weighs a lot more than the pt stuff so you will be adding weight to the trailer:eek: .
/ Trailer decking #24
I hear locust wood is pretty tough stuff without treatment as well. ( not sure black or honey? )
soundguy
/ Trailer decking #25
Catalpa is extremely rot resistant also. Only prob is, good luck finding a branch straight enough to make a board out of. Maybe you can use the trunk.
/ Trailer decking #26
EPA would poop kitttens if they knew how many gallons of used motor oil was spread over the cemetery roads to keep the dust down. My wifes grandfather started the practice but we stopped many years ago.
/ Trailer decking #27
There is a term for the type of decking that is used on some trailers in the trucking industry. I think the spelling is correct- "aptong".
I've re-decked some trailers, and replaced a few damaged or rotted boards on others, usually getting the decking from the trailer manufacturer. The boards have a very tight grain, pretty sure it's oak, and I think the name "aptong" refers to the treatment/or preservative used on them. They can be purchased in several different widths, normally 6" or 8", and come tongue and groove, (might not be correct on the next two terms, "lap board, and ship lap", which refers to the way the board edges are finished so that they can interlock with each other.
This makes a very strong, long lasting trailer deck, supporting all types of equipment to be hauled, and forklift traffic traveling on the trailer during the loading and unloading operation. Naturally, more expensive than normal treated boards, but this stuff LASTED!
For further insurance on our flatbed decks that stayed exposed to the elements, we coated them with a marine type of coating that contained copper, which was really almost overkill.
/ Trailer decking #28
Apitong is a type of very tough Asian hardwood used in expensive commercial trailer decks, not a term or a process. I understand it is hard as woodpecker lips.
/ Trailer decking #29
Talking about double standards, asphalt paving when used in streets is considered OK, but dig it up and suddenly it becomes "toxic waste" and must be disposed up in a proper HazMat landfill or recycled back into a "safe" product. Repaving just one road probably adds more toxic materials to the environment than treating all the trailer decks Florida.
Go figure.
/ Trailer decking #30
Go figure.
that must be a 'stupidfornia' thing. 99% of the elements found on/in the earth are illegal or cause cancer there. :(
around here, asphalt millings and crushed concrete are considered 'clean fill' for putting in subgrade for stabilization..e tc... and they can go into an unlined C&D landfill. ( construction debris )
the bituminous mix is virtually inert once cured anyway.. and heck.. I guess CA forgets the precursor of this is pumpe dout of the ground anyway.. :)
/ Trailer decking #31
Really...
/ Trailer decking #32
really what?
/ Trailer decking #33
A friend of mine re-decked his 16' trailer with C purlins which is a light gauge steel (C shaped). It is much lighter and also stronger than the wood. He also was able to install D rings in it where ever he wanted. He then sprayed bed liner on it. I borrowed it a few times. It was awesome.
/ Trailer decking #35
...If you lived around me .. Middle of Texas . We have 2 places for flooring. One is a saw mill that saws up HiLine poles & telephone poles. Makes a good floor.
... & 2ND MY Running Buddy makes water well sucker rods. They use Ash lumber and it starts out as about 22 ft . Most of it is 5Qt's ..The scrap that he generates is sold as flooring material ...
/ Trailer decking #36
I didn't say eat it. I merely said that it's still fairly safe. VOC's leach of paint on houses.
leaky cars depost used oil ( hazardous waste) on roads.. and that leaches.
till we find a better pavement.. that's what we have.
the fact that california finds something toxic is no big surprise. like I said. they find most things toxic.
your sarcasm is appreciated.. might as well say something like that then say nothing right? probably another ca thing.
must be the lead and poly cyclic toxins... go figure huh?
health is a '1'
http://www.tsocorp.com/stellent/groups/corpcomm/documents/tsocorp_documents/msdsasphalt.pdf
I'm just amazed that given your vast knowledge, that the University of Florida did not contact you. They could have saved thousands. :confused2:
http://www.beyondroads.com/visual_assets/RAP_Leachability_Study.PDF
/ Trailer decking #38
I didn't read that in your post. Must have missed it.
if you have to be told not to eat asphalt. I guess CA is the place to live... eh?
/ Trailer decking #39
I notice that the wind in florida changes direction quite frequently. What direction is your wind blowing today?
/ Trailer decking #40
wait.. I know how to fix this.. ( clicking sounds )
Ahh.. all better now.
Back to tractor message reading...
1000bu FEED BIN (A64277)
1000bu FEED BIN...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
2004 John Deere 693 Cornhead (A66285)
2004 John Deere...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
New/Unused Landhonor Quick Attach Grapple Bucket (A65583)
New/Unused...
