Trailer Decision - Pros / Cons
/ Trailer Decision - Pros / Cons #21
I do live in the NE, but I don't think the trailer will see much use during the winter, so not too concerned w/ corrosion issues, but I think the durability of a steel trailer would be a plus for my application, so I think I'm eliminating the aluminum options for now. That Nordtek is nice, but may be a bit out of my price range right now (under $10k would be ideal).
I'm narrowed down to one of these 14k Iron Bull options in 22' x 83". They seem to hit a sweet spot in build quality vs price from what I can tell.
Regular Flatbed w/ Mega/'Rampage' Ramps, ~10,500# usable, cheapest option @ $6,800
Channel Construction Tilt-bed, 11 degree tilt, ~9,900 usable capacity, ~$9,700
I-Beam Tilt-bed, 14 degree tilt, ~9,700# usable. Waiting on quote, est. ~$8,300(?)
Since I probably can't pull a SS/TLB w/ my current truck w/o going CDL anyway, the heaviest load I would have would be my Compact Tractor, which should be ~6500# max w/ loader and backhoe. Even with an extra implement (or two) I think I would be well within all the weight limits regardless of choice, but leaning towards the last one ATM, w/ the I-beam construction, tilt-deck, and std. toolbox.
Is this commercial or personal use? If personal use, your not in commerce no CDL would ve required at least federal unless there is a state requirement.
Per my original post, my intention is to start providing some tractor services in my area, so yes, commercial.
I won't need a CDL for the 3 trailers that I'm currently considering for use w/ my current tractor, but I was originally thinking I would get a CTL down the road. I was hoping that I could get a trailer w/ this in mind. But, in Post #7 above, I realized and explained that w/ my current truck's 11.3k# GVWR, any trailer rated over ~14.5k would put me over 26k# GCVWR.
If I do end up w/ a CTL down the road, I'm thinking I will need ~12k# of usable weight limit if it has a heavy mulching head on it, which I don't think I'm going to get w/ a trailer rated at 14k. At that point, I'd need either the CDL and a heavier trailer, or I would need something like a 16k trailer and a truck de-rated to 10k to keep me under the 26k# limit (not sure if this is a federal requirement, but it seems that most states in the NE have this limit from what I've seen).
/ Trailer Decision - Pros / Cons #23
You may not need a CDL but you will need DOT numbers.
/ Trailer Decision - Pros / Cons #25
If the cheaper price of the Applacian trailer scares you away keep in mind that your buying directly from the manufacturer. More than likely your buying from a middle man for the rest of them.
Total transparency..I bought a new 10k Appalachian in 2023 and have been happy with it. It saved me about $1600 vs others..this is on a $5300 trailer so that's quite a bit. Towed it thousands of miles so far. I tow a 7,000lb tractor and a 3,500lb micro ex.
The Appalachian is ruled out because the 15k rating puts me in CDL territory.
I'm settled on this one - picking up on Mon:
If I end up w/ a CTL down the road that exceeds the trailer's rating, I'll cross that bridge when I come to it.
/ Trailer Decision - Pros / Cons #27
Cant you register things for less than the gVW on the tag?
Yes, you can. Not sure if the process is consistent across states(?).
W/ a trailer, in the NE, it's my understanding you need to order it derated or get a new COO and a sticker from the manufacturer, which many are willing to provide. But, if I understand correctly, when you derate the trailer, that comes out of the cargo capacity. If you derate a 14k equipment trailer to 12k, the actual weight of the trailer stays the same, so you now subtract the weight of the trailer (~4k#) from the 12k rather than 14k to get your max cargo rating.
With the truck, you can get 'packages' that derate the GVWR, and I don't think it's possible to derate the truck from the manufacturer once it's been built. I could've ordered my truck (w/ a 11,300# GVWR) w/ the '10k#' package and got the same exact truck except for the sticker. But, at the time, I was planning on getting a 5th wheel RV and I wanted the max cargo capacity for the 5th Wheel, since your 5th wheel pin weight counts against your cargo capacity. IIRC, the 10k# package would've lowered my 5th wheel max trailer weight by ~900#, though I don't think it changes the bumper pull ratings, so in theory, I could tow a heavier bumper-pull trailer (ex - up to a 16k# equipment trailer) w/ the 10k# truck package and stay under the 26k# CDW requirement. With my current truck, w/ a 14k trailer, I can theoretically max out the trailer's GVWR (which 13% of maxes out my hitch rating @1,820#), and I still have ~1,500# of cargo that I can put in the bed or cab.
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
(2) FORESTRY TIRES ONLY (A64276)
(2) FORESTRY TIRES...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
