Trailer brakes
/ Trailer brakes
Thanks for all the replies. I found my problem. The wires to one of the magnets were not tucked in properly. It rubbed against the drum. Therefore, a shorted condition occured (OL). I wiretied it back and checked. I think I will need to get new pads. They feel they need ajustment. I made a test light with a 50w 12v halogen lamp so I could prove my controller was good. Made a good load.
/ Trailer brakes #12
I built a trailer wire it carefully. When I hooked up the trailer brakes the controller appeared like it was happy. When I am moving and try to apply the brakes I get a OL on the controller. The brakes do not seem to work. I guess I will need to troubleshoot it over the weekend. It appears only two wires are involved, ground (white) and brakes (blue). I was told that the magnets are not polarity sensitive. Any ideas.
If you have a gm vehicle with the 7 pin connector on it, and have a 7 to 6 converter for a 6 pin trailer, and aure using a stock harness pigtail connector to connect your controller to the vehicle.. then you will likely have to swap 2 wires in the 7to6 converter.
otherwise it's like the guys said.. power, ground, brake sens, and power to the brake magnets.. other side of magnets to ground.
soundguy
2024 Linx Trailer (A60462)
2024 Linx Trailer...
204549 (A52707)
204549 (A52707)
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
TULSA WINCH (A60736)
2019 FREIGHTLINER M2 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2019 FREIGHTLINER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
