Trailer bounce
/ Trailer bounce #31
azop said:
Thanks. I just went out with a flashlight hoping to see some indentation. I did notice that according to the tag on the side, it has a gross weight of 7000 pounds, and it's actually 18ft x 82 inches, not 16ft.
Do you know which side the stamping might be for the ball size?
I guess I'll call the manufacturer tomorrow and see if they can look up the VIN to see what was *suppose* to be on there, assuming nobody hacked it off and welded another ball size on.
Do you have a 2 5/16 ball to try in the coupler or can you borrow one? What kind of coupler is on the trailer?
/ Trailer bounce #32
I was just looking at the picture from the link you posted earlier from the Bobcat dealer. Think a 2" coupler at over a 1/4" if you had the wrong size ball when he loaded the tractor even if was grabing coupling latch a little it I think trailer would've went straight up off ball with that much force on it. I googled LOADMASTER
Is it these people
Equipment & Car Haulers
Says the standard hauler they make is a 2" coupler the Heavy Equipment Hauler is a 2-5/16 6k axles
you said tag said 7k weight makes it the 3500 so the 2"coupler per the website if right manufactuer
The coupling should be stamped right above ball or on plate that is welded to tounge
/ Trailer bounce
Yep...brand new ball and hitch. I will work on pictures asap...and look a third time for the ball size stamp.
The latch that secures the ball to the coupler was missing, but the dealer replaced it prior to me picking it up.
/ Trailer bounce #35
That sounds scary. The coupler isn't the old style you turn the knob and tighten down is it?
I know this is not why trailer was giving problems but it may save your tailgate. When you sit the trailer on the ball and latch it run the jack down til it starts to pick the back of the truck up or you pick up on it by hand to be sure the ball is latched in the coupler. I know some people who have had the coupler on top of the ball and thought it was latched on the ball and trailer came unhooked when they moved the trailer or tried loading something on the trailer.
/ Trailer bounce #36
I would guess that you have "BIAS PLY" tires on the trailer rather than "RADIAL PLY" and with your cold weather the bias ply tires develop flat spots where they are parked. When you drive, it goes.... bump, bump, bump, bump with every revolution. The faster you go the faster the bump bump bump and once you get over 40 mph it feels smoother while under 40 mph feels worse.
This is just the way bias ply tires are in cold weather. It would take many miles at high speed to warm them up and make the flat spots go away.
And since you are new to towing, yes you will feel the trailer move you around and bounce you. It makes your truck bounce in a quick, jarring type motion. The kind you feel in your neck like whiplash. Not a smooth bounce like when not towing. Though sometimes you will get a forward and backward surging feeling if the load is heavy, like towing your tractor. You will get use to what is normal and then you can feel if something is wrong or loose.
Swaying is when the trailer starts to whip left and right, usually into the lanes next to you. This is VERY scary and very serious and will pull your truck with it. You never want this. This is caused by not enough tongue weight (weight on the front of the trailer) and too much on the back of the trailer. Swaying usually occurs over 45 mph (that is why uHaul trailers all have 45mph speed limit stickers on them). The next sway threshold is about 60 mph. Swaying is usually worse when going downhill and very hard to get back under control.
If you ever get into a swaying situation... Let off the throttle for sure but be very smooth (no sudden movements at all), then stay very, very light on the brake, too much braking will make it worse. But you do need to slow down and the preferred way to slow down is to NOT use the towing vehicle brake at all but instead manually activate the trailer brakes with the thumb slide on the controller. This will cause the trailer to slow down while you coast, this pulls everything straight and keeps the hitch tight. Also, be very light with the steering wheel, don't try to compensate as you will usually make the swaying worse. Just keep it going as straight as you can. If you ever get to really swaying far, you will probably take 1/4 mile to get it under control. You want to be very smooth and don't try to slow the towing vehicle down fast. A swaying trailer is trying to pass you and slowing down the tow vehicle fast helps it try to pass you. Usually resulting in jack-knife. Most important is to use the trailer brakes and then slow as fast as possible. With the trailer doing the braking you can put them on hard but don't lock them up. Activate the thumb control slow, don't slam it all the way. If the trailer skids, release and start braking again. Slow and smooth is the key to all of this.
Gene :^)
Note: I have towed my tractor forward and backward on the trailer. Doesn't make any difference so long as the load is balanced correctly for proper tongue weight.
Note 2: The ball size is normally stamped facing up on the coupler. Sometimes right on top of where the ball goes or just behind the latch with the other wording. Just look for a 2" or 2 5/16" They look quite different from each other even if it is not readable. Or just hold your hitch in your hand and put it up into the coupler, then lock it and see if you have a lot of play. The 2 inch coupler on a 2 inch ball will be pretty tight when latched. The 2 5/16 coupler on 2 inch ball will almost fall out or might fall out when latched. Will have alot of play for sure. I would guess that your dealer would not make a mistake in this area, it is very important and he wouldn't let you leave the lot with the wrong size.
Note 3: If the latch is the folding back type with the little lock lever, it is normal to take off or replace these. Look underneath and you will see a large nut to adjust the tightness. You may need to adjust this and should check it every couple years. Again hold your hitch in your hand and lock it into the coupler. If it is too tight, you take the hitch out and then loosen the nut half a turn. Then re-check the fit by locking the hitch back in. If it is too loose, you take the hitch out and then tighten the nut half a turn. Of course it doesn't have to be 1/2 turn increments, turn it whatever amount makes it fit good. You don't want play but you also want it to turn and move freely in there.
Note 4: Get yourself a can of grease with a plastic lid at the auto parts store and keep it with your trailer stuff. They are about 4 inch diameter and 3 inches tall. Then for regular maintenance before you attach your trailer you remove the plastic lid, turn the can upside down, and dip it (just barely) onto the top/tip of your towball. This will leave a small blob of grease on top of the ball. Then couple your trailer and the grease will get pushed around up inside the coupler and ball.
Always keep the ball greased and coupler adjusted proper. And always have a locking pin (clevis) or padlock on the coupler to keep it shut when towing.
/ Trailer bounce #37
Definitely check the adjustment on the coupler and the ball size.
Don't assume the dealer gave you good information. My flat bed bought in Washington State was a 2 5/16, the cargo I bought in Georgia was the same. Be carful with the trailer balls, as stated before, not all are created equally. OK, that does sound a little funny :) but make sure it has the correct weight rating. By the way, if it is a 2 .5/16 they may have tightened it down a bunch and a 2" will "hold" it for a little while.
A undersized ball will make a bounce show where one normally wouldn't notice. It'd jerk a bit though and not be a smooth one.
/ Trailer bounce #39
There is a nut on the under side of that type of hitch. You can tighten the nut up so that the latch fits more snug up to the ball.
/ Trailer bounce #40
I think I have the same trailer! Electric brakes.. Etc. But the guys above are right. Sound like a loading issue and getting the weight distributed correctly. An easy way to confirm it is to pull it empty and see how she handles. If you have the same problem then I'd check your rear shocks. They may be worn. Assuming TP has been checked and the thing isn't bent up. Sometimes the roads will throw you around but for me that's always been side to side and I could tell by the road condition it was coming. Worst road I've towed on was East of Chicago two (3?) years ago on 90. They had just prepped it for repaving and did a horrible job.
East of Chicago?
Isnt most of that Lake Michigan?
:laughing:
2005 JOHN DEERE 160C LC EXCAVATOR (A59823)
2005 JOHN DEERE...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
Champion 540P (A60462)
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
