Trailer bounce
/ Trailer bounce #21
My tractor weighs around 3600 lbs and I haul it on a similar type trailer as yours with dual axles and a GVW of 7000 lbs. Tow truck is a 1500 GMC, 4 WD, pickup. I experience a re-occuring rythmic bounce at 55 to 60 mph when traveling on most concrete pavement roads. The problem goes away as soon as I am back on an asphalt or bituminous road surface. Generally, I try to avoid the concrete pavement when possible. I think it is related to the spacing of the joints in the pavement and perhaps the spacing of pickup and trailer axles.
/ Trailer bounce #23
I noticed where the ball hitch connects to the truck that the ball hitch is a little loose. Is this normal, or did I get the wrong size ball hitch? The ball is a 2 inch ball, which matches what the trailer accepts.
(I'm talking about the the hitch similar to this: http://images.campingworld.com/is/image/cwi/3000/34578n2.jpg?wid=500)
You mean you have space(room) on the tounge around the circumference of the ball that you just need to tighen the latch on coupler or you put the hitch mount into the reciever place the hitch pin through and it just feels loose you can jiggle it a little bit= Normal they only make the 1-1/4" and
2" makes it kinda hard to get wrong one might have been a slop job
Do you have the pics of it loaded with and without tractor yet? that will give us a better idea
I am surprised you have a 2" ball though I am not sure but I think max is 5k on those anybody
I think you are suppose to have a 2-5/16" ball thats what my trailer is a 7K+ brakes on both axles I do not know much about these little trailers
On your tounge where the coupler is what exactly does it say????? I also think a 2" coupler is only rated at 5kmax anybody?
I will look around online and see what I find
Scratch
Edit: Trailer hitch, hitches and bike rack (800)298-8924 On ball found up to 8K most everything else 6K or less and coupler if it is a Bulldog they have a 7k and a 8k otherwise 6k or less
I did go look look at mine ball is a 2 5/516 rated 10K hitch V rated 1200 Pound tongue Weight 12000 Pound towing and ball mount Class IV 10000 lbs coupler is a Fulton Class4 max12,500 Trailer is a 20' car hauler has working breakaway and brakes on both axles. Not sure what your state requires check the trailer section here they have some good sites for you to take a look at most are 3500 or more require brakes on one I even think Ny was now 1500lbs better now.
Im not making waves just trying to get the info
/ Trailer bounce #24
What kind of coupler is on the trailer? My trailer only has a 2" coupler. The ball and mount I have is rated for 7500 pounds. Some 2 5/16 are only 5000 pounds. You just have to check and see what the ball says and mount. Not always does a bigger shank means more gross weight.
/ Trailer bounce
I do not have pictures of it attached to the truck yet. Todays "dusting" of snow turned into 8 inches, so it's a sloppy mess. I did drive it to my parents house and experienced the same problem with the tractor backed on the trailer. A friend suggested I park the tractor over the double axles and put the bucket down on the dovetail end. Later this week I should have pictures on level ground, when it's not dark and crappy.
/ Trailer bounce #26
There is 99 % chance you got the wrong ball. I count 5 lugs on your trailer tire, making it a 3500k for each tire telling me you have a 7k or so rated trailer. I don't want to argue with anyone, but many 2 inch balls are only rated at 4-5k. a few are rated at 7000. GO to your trailer and look at the coupler. chances are you are going to find a 2 5/16 stamped on it.
If you did indeed have wrong ball- count your lucky stars that NOTHING happened to your trailer and tractor and you got home ok. chances are your insurance WILL NOT cover your tractor in accident if it fell off unless you got a rider.
/ Trailer bounce
Eek. That's what I get for listening to the dealer. I asked what ball hitch I needed and he told me 2 inch, and he claimed that he measured it because he thought it was a 2 5/16 (The dealer had it moved from another Bobcat store, so he didn't have direct knowledge of it). I'll check first thing in the morning, but when I looked over it briefly when I purchased it I didn't see *any* stamping around the coupler.
Thanks!
/ Trailer bounce #28
you might not see the stamped weight rating since the spray paint makes it hard to see. look during daylight and maybe bring sheet of paper and crayon and make a imprint . you will see the stamped lettering better.
/ Trailer bounce
Thanks. I just went out with a flashlight hoping to see some indentation. I did notice that according to the tag on the side, it has a gross weight of 7000 pounds, and it's actually 18ft x 82 inches, not 16ft.
Do you know which side the stamping might be for the ball size?
I guess I'll call the manufacturer tomorrow and see if they can look up the VIN to see what was *suppose* to be on there, assuming nobody hacked it off and welded another ball size on.
/ Trailer bounce #30
First off for safety sakes make sure your trailer and ball are rated for reach other. A 2 5/16 hitch will seperate from a 2 inch ball. I found this out years ago while moving my empty 2 5/16" 16 foot 3 axel trailer around in my yard with a 2" ball. I just didn't take time to swap balls.
The bouncing I have with this 3 axel trailer is much worse when towing unloaded. It feels like 3 200lb men are jumping on my rear bumper twice per second.
This is what I think is happening. This trailer is a heavy bumper pull type. There are springs without shocks on the trailer. When the trailer hits a bump it causes a resonating effect. If the trailer had shocks then this reasonating effect would be arrested by shock absorbers. Please correct me If my thoughts are wrong, but I think the trailer is see-sawing a few inches up then down on its axels. When the trailer sits up too high in the front it bounces even more.
Things that I find help correct these actions. Good truck shocks, load leveling hitch, weight on the trailer, properly adjusting the latch nut on the hitch, smooth roads and a 2 inch drop down hitch.
My other 16' 2 axel trailer has a non-adjustable bull dog type hitch and it never bounces.
For the record my tow vehicle is a 96 Cummins 3500 ext cab Dodge ram which is very light in the rear.
/ Trailer bounce #31
Do you have a 2 5/16 ball to try in the coupler or can you borrow one? What kind of coupler is on the trailer?
/ Trailer bounce #32
I was just looking at the picture from the link you posted earlier from the Bobcat dealer. Think a 2" coupler at over a 1/4" if you had the wrong size ball when he loaded the tractor even if was grabing coupling latch a little it I think trailer would've went straight up off ball with that much force on it. I googled LOADMASTER
Is it these people
Equipment & Car Haulers
Says the standard hauler they make is a 2" coupler the Heavy Equipment Hauler is a 2-5/16 6k axles
you said tag said 7k weight makes it the 3500 so the 2"coupler per the website if right manufactuer
The coupling should be stamped right above ball or on plate that is welded to tounge
/ Trailer bounce
Yep...brand new ball and hitch. I will work on pictures asap...and look a third time for the ball size stamp.
The latch that secures the ball to the coupler was missing, but the dealer replaced it prior to me picking it up.
/ Trailer bounce #35
That sounds scary. The coupler isn't the old style you turn the knob and tighten down is it?
I know this is not why trailer was giving problems but it may save your tailgate. When you sit the trailer on the ball and latch it run the jack down til it starts to pick the back of the truck up or you pick up on it by hand to be sure the ball is latched in the coupler. I know some people who have had the coupler on top of the ball and thought it was latched on the ball and trailer came unhooked when they moved the trailer or tried loading something on the trailer.
/ Trailer bounce #36
I would guess that you have "BIAS PLY" tires on the trailer rather than "RADIAL PLY" and with your cold weather the bias ply tires develop flat spots where they are parked. When you drive, it goes.... bump, bump, bump, bump with every revolution. The faster you go the faster the bump bump bump and once you get over 40 mph it feels smoother while under 40 mph feels worse.
This is just the way bias ply tires are in cold weather. It would take many miles at high speed to warm them up and make the flat spots go away.
And since you are new to towing, yes you will feel the trailer move you around and bounce you. It makes your truck bounce in a quick, jarring type motion. The kind you feel in your neck like whiplash. Not a smooth bounce like when not towing. Though sometimes you will get a forward and backward surging feeling if the load is heavy, like towing your tractor. You will get use to what is normal and then you can feel if something is wrong or loose.
Swaying is when the trailer starts to whip left and right, usually into the lanes next to you. This is VERY scary and very serious and will pull your truck with it. You never want this. This is caused by not enough tongue weight (weight on the front of the trailer) and too much on the back of the trailer. Swaying usually occurs over 45 mph (that is why uHaul trailers all have 45mph speed limit stickers on them). The next sway threshold is about 60 mph. Swaying is usually worse when going downhill and very hard to get back under control.
If you ever get into a swaying situation... Let off the throttle for sure but be very smooth (no sudden movements at all), then stay very, very light on the brake, too much braking will make it worse. But you do need to slow down and the preferred way to slow down is to NOT use the towing vehicle brake at all but instead manually activate the trailer brakes with the thumb slide on the controller. This will cause the trailer to slow down while you coast, this pulls everything straight and keeps the hitch tight. Also, be very light with the steering wheel, don't try to compensate as you will usually make the swaying worse. Just keep it going as straight as you can. If you ever get to really swaying far, you will probably take 1/4 mile to get it under control. You want to be very smooth and don't try to slow the towing vehicle down fast. A swaying trailer is trying to pass you and slowing down the tow vehicle fast helps it try to pass you. Usually resulting in jack-knife. Most important is to use the trailer brakes and then slow as fast as possible. With the trailer doing the braking you can put them on hard but don't lock them up. Activate the thumb control slow, don't slam it all the way. If the trailer skids, release and start braking again. Slow and smooth is the key to all of this.
Gene :^)
Note: I have towed my tractor forward and backward on the trailer. Doesn't make any difference so long as the load is balanced correctly for proper tongue weight.
Note 2: The ball size is normally stamped facing up on the coupler. Sometimes right on top of where the ball goes or just behind the latch with the other wording. Just look for a 2" or 2 5/16" They look quite different from each other even if it is not readable. Or just hold your hitch in your hand and put it up into the coupler, then lock it and see if you have a lot of play. The 2 inch coupler on a 2 inch ball will be pretty tight when latched. The 2 5/16 coupler on 2 inch ball will almost fall out or might fall out when latched. Will have alot of play for sure. I would guess that your dealer would not make a mistake in this area, it is very important and he wouldn't let you leave the lot with the wrong size.
Note 3: If the latch is the folding back type with the little lock lever, it is normal to take off or replace these. Look underneath and you will see a large nut to adjust the tightness. You may need to adjust this and should check it every couple years. Again hold your hitch in your hand and lock it into the coupler. If it is too tight, you take the hitch out and then loosen the nut half a turn. Then re-check the fit by locking the hitch back in. If it is too loose, you take the hitch out and then tighten the nut half a turn. Of course it doesn't have to be 1/2 turn increments, turn it whatever amount makes it fit good. You don't want play but you also want it to turn and move freely in there.
Note 4: Get yourself a can of grease with a plastic lid at the auto parts store and keep it with your trailer stuff. They are about 4 inch diameter and 3 inches tall. Then for regular maintenance before you attach your trailer you remove the plastic lid, turn the can upside down, and dip it (just barely) onto the top/tip of your towball. This will leave a small blob of grease on top of the ball. Then couple your trailer and the grease will get pushed around up inside the coupler and ball.
Always keep the ball greased and coupler adjusted proper. And always have a locking pin (clevis) or padlock on the coupler to keep it shut when towing.
/ Trailer bounce #37
Definitely check the adjustment on the coupler and the ball size.
Don't assume the dealer gave you good information. My flat bed bought in Washington State was a 2 5/16, the cargo I bought in Georgia was the same. Be carful with the trailer balls, as stated before, not all are created equally. OK, that does sound a little funny :) but make sure it has the correct weight rating. By the way, if it is a 2 .5/16 they may have tightened it down a bunch and a 2" will "hold" it for a little while.
A undersized ball will make a bounce show where one normally wouldn't notice. It'd jerk a bit though and not be a smooth one.
/ Trailer bounce #39
There is a nut on the under side of that type of hitch. You can tighten the nut up so that the latch fits more snug up to the ball.
/ Trailer bounce #40
I think I have the same trailer! Electric brakes.. Etc. But the guys above are right. Sound like a loading issue and getting the weight distributed correctly. An easy way to confirm it is to pull it empty and see how she handles. If you have the same problem then I'd check your rear shocks. They may be worn. Assuming TP has been checked and the thing isn't bent up. Sometimes the roads will throw you around but for me that's always been side to side and I could tell by the road condition it was coming. Worst road I've towed on was East of Chicago two (3?) years ago on 90. They had just prepped it for repaving and did a horrible job.
East of Chicago?
Isnt most of that Lake Michigan?
:laughing:
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2021 John Deere 50G Mini Excavator (A62613)
2021 John Deere...
Frontier RC2072 (A64126)
Frontier RC2072...
2023 Kubota Z232 (A64127)
2023 Kubota Z232...
