trailer ball on a box blade?
/ trailer ball on a box blade? #1
clovergamecock
Clover SC
Kubota L2800 4WD FEL
I just finished putting a new bed, sides and wheel bearings on a trailer that was given to me. I have a pretty good sized property including an area we just had a house moved from that needs a lot of clean up. I am using my box blade extensively and I don't see that changing any time soon. Removing the box is a lot of trouble every time I need to take the trailer out to the site with all my shovels, chain saw, gas etc..... Has anyone ever attempte to put a trailer ball in the back face of a box blade? If so how?
Thanks
Wade
/ trailer ball on a box blade? #2
I think the easiest would be to simply weld a trailer hitch receiver onto the rear end of the box blade. I don't have a welder, so I'm contemplating my own way to fabricate this, but it's not looking good yet.
I'd like to have a trailer ball on the rear of my 6' blade as well as the box blade.
/ trailer ball on a box blade? #3
You can bolt or weld a piece of angle iron on to the back of your box blade to mount a trailer ball or receiver onto. I have a piece of flat bar scrap on my back blade, needed it quick and still there 20 yrs later, not painted, only a little bent.
Cam
/ trailer ball on a box blade? #4
I have seen some the ball is just welded to back plate,just used to move empty trailer around nothing really heavy... The reciever would be a better route to me would put the trailer alittle further back for turning and could use multi. Different reciever,probaly have to clear the dirt sometimes.
/ trailer ball on a box blade? #5
I bought a box blade 15 yrs back used, it already had a ball mounted to the top edge, they just drilled a hole in the top lip and bolted the ball on. I do think a piece of angle bolted on the back of the blade would work better. I don't see where it would be in the way of anything and if it got covered in dirt, wouldn't hurt anything.
I built a section harrow and put a reese tube on the back of it. By it being extended back from the tractor, unless the trailer is loaded really heavy, it works great just to move a trailer around.
/ trailer ball on a box blade? #7
Yep, I've got a receiver welded on top of the bb. I have a nice trailer mover but the box blade is usually already on the tractor so it certainly made life more convenient.
/ trailer ball on a box blade? #8
I have a Rhino BX66 box blade that I just drilled a hole in the top lip of the blade for the ball. It has worked very well and been on there for more than 10 years without bending. The top of the blade is folded back about 2". It is 1/4" steel I think.
Tim
/ trailer ball on a box blade? #9
I welded a hunk of 3/8" flat bar onto mine with a hole for a ball mount. that was the first week I bought it. I wish I had put on a receiver tube though as would be much easier to change ball mounts or ball sizes or adding a snatch hook etc ...
HF has them on sale right now 18" receiver tubes that is. you can also weld on an old truck receiver which is what I welded onto my FEL bucket...
Mark
/ trailer ball on a box blade? #10
I put my trailer ball on the front tractor bumper. It is much easy to maneuver a trailer pulled from the front instead of the rear and I don't have to worry about changing anything on the rear of the tractor.
/ trailer ball on a box blade? #11
I did this a long time ago; I use it frequently. One of the better "upgrades" I have done as far as tractoring goes.
I mounted a reinforced tab at about the 2/3-3/4 height point of the scraper. In my case, mounting the ball on the top lip of the scraper would have put it up too high
Use it frequently with 8' utility trailer around the property. It is handy for parking both of my trailers; my storage spot is kind of a pain to manuever in to with the truck.
I would just be cautious; Don't put a bazzilllion pound loaded trailer on and break your 3pt hitch or bend the arms. And remember, it's a lot more to stop once you get rolling.
/ trailer ball on a box blade? #12
My FIL has holes in the back frame of his BB for trailer balls. Works well for him since his MF165 seriously out weighs his trailers.
Kubota B21 TLB (A60462)
Kubota B21 TLB...
SWICT 60" SKID STEER BUCKET (A60430)
SWICT 60" SKID...
UNUSED 31" HYD TILT MINI EXCAVATOR BUCKET (A60432)
UNUSED 31" HYD...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
2017 Scag Cheetah 61in Zero Turn Commercial Mower (A59228)
2017 Scag Cheetah...
2020 JOHN DEERE SUV590M S4 GATOR (A60430)
2020 JOHN DEERE...
