Trailer Ball Mount or Receiver Hitch to replace bucket on BX25
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #1
Johnkn
Platinum Member
Laplata, MD
Kubota LX3310
Hi, does anyone make either a trailer ball mount or Receiver tube that could mount to the Quick Attach replacing the FEL on a BX25D? I'd like to use the BX for moving a trailer around and seems it would be much easier and comfortable to mount to the front of the tractor rather than the 3 point hitch. thanks
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #2
There are other solutions that clamp to the FEL and allow u to use a ball for moving trailers.
Sent from my iPhone using TractorByNet
I've see the clamp hitch by Paynes and read some reviews here about it sliding around and moving. Also considering buying a BXpanded bucket hook w/o the actual hook and welding a short piece of 2" receiver to it. Worst case, I can fab something that mounts to the QA on the BX25D. thanks
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #4
You could get one of these QA hitch with Reese style mount.
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #5
You might be able to add a receiver to the Kubota quick attach, sort of like this one. It doesn't have to be exactly centered. Offset a bit to the side may make it easier to hook up.
Bruce
Quick Attach intro
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #6
I had a 2" ball mounted onto the bucket of my BX-25. It works well for short moves.
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #7
I can see that being handy, but when you are hooking up to a trailer, the rear mount affords better visibility.
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #8
Oh, one other thing.......moving a trailer using the front hitch takes a bit of getting used to how the trailer moves. The steering is sketchy at best. For short moves it is OK but for long moves it becomes a PIA. If you move a trailer using a rear three point (like my 2620) the hitch can come up as the tph only lifts and doesn't hold the trailer down....found that the hard way after I had to replace my boat's prop. Live and learn!
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #9
If you think one on the front is a PIA, try two! :laughing:
With a little practice one is easy. The key is to watch the rear end of the trailer and steer it where you want to go. :thumbsup:
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #10
Johnkn,
I fabricated with minimal skill, this receiver mount. I used a piece of 1/4 plate steel and bent it to wrap around the cutting edge of the bucket (keeps it from sliding). Drilled two 9/16" holes in the bucket to attach two bolts with wing nuts. I takes about one minute to put it on. I think it works better than welding the receiver to the top of the bucket, you can get under trailers without having to have them up high off the ground.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
JOHN DEERE 4730 LOT NUMBER 256 (A53084)
JOHN DEERE 4730...
2019 Yamaha Electric Golf Cart (A51573)
2019 Yamaha...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
ASSET DESCRIPTIONS & CONDITION (A52577)
ASSET DESCRIPTIONS...
CATERPILLAR V50B STRAIGHT MAST FORKLIFT (A51246)
CATERPILLAR V50B...
