Trailer Axle and Tires
   / Trailer Axle and Tires #1
rah6965
Carthage/Sanford North Carolina
New Holland TC48DA
I need some help with determining which type trailer springs are best. I have decided to replace the mobile home axles on a used trailer I bought with some Dexter axles from a local trailer mfg. I plan to replace axles, springs and mounting bolts. I also plan on replacing the center equalizer hanger, since the old one has a lot of wear on it. Basically I plan on replacing everything but the welded-on hanger plates. The old trailer has tandem slipper springs now. The new axles will be dual 6,000 lb. dexter brake axles. Is there any real difference in double eye springs and slipper springs. What are the advantages or disadvantages to each type of spring. I will also replace the old wedge bolt M/H tires with some 8 bolt wheels and tires. I found some 8 X 14.5 load range G tires and 8 bolt wheels made by LoadStar. Does anyone have any comments on this type or brand of tire. I was thinking about using these because they are the same size as the existing M/H tires on my trailer. I'm afraid I may have clearance issues with 235/80/R16 tires on this trailer. Thanks for any input.
:confused:
   / Trailer Axle and Tires #2
I do not like slipper set-ups with equalizers. So that being said I would go with the dual eye springs. Now, are you sure the 6.0K axles are 8 lug. All 5.2K and 6.0K axles I see are 6 lug. You have to go to 7.0K and 8.0K before you get into 8 lug. The Loadstar tire seems ok but I have never used them. I really like GreenBall Tow Masters. Norther Tool is a big retailer for them.
Chris
They could be 6 lug wheels. I will have to ask again to make sure. So, you recommend the double eye type springs over slipper springs. Thanks for the input Chris.
   / Trailer Axle and Tires #4
Not really recommending them, just that is what I usually see. I would ask a spring shop that works on trailers suspensions.
Chris
   / Trailer Axle and Tires #5
I would definitely recommend bias ST tires over radial ST tires. Radial may roll easier but contribute to sway because of the weak sidewalls and are very easily damaged by curbing. If overloaded or curbed, the radials are VERY prone to blowouts. When used for heavy load carrying trailer service, bias ST tires are the way to go.
   / Trailer Axle and Tires #6
That is funny you say that. I have never had any luck with bias tires. I guess its a Ford Cheby fight, I am a Ford Guy.
Chris
Thanks for the input. The 8 X 14.5 are load range G (14 ply rated) and they are bias-ply tires. I worked at a Michelin aircraft tire plant for 11 years and all our aircraft tires were bias-ply. They were really heavy duty and had super stiff sidewalls. They would make great trailer tires, but you would need a split rim wheel to mount them. Back to my spring question; What do most new equipment trailer mfg. companies use (slipper or double eye) springs? I've looked at several trailer websites, but you can't determine their axle spring type without giving them a call.
   / Trailer Axle and Tires #8
My experience is with slipper type springs and the 8-14.5 bias tires. I have not had any problems in the 12 years owning this trailer. I estimate the trailer has at least 35k miles on it and the usual load weighs around 12k pounds.
   / Trailer Axle and Tires #9
Chris
Nah, there's no fight, I'm a Ford guy through and through!:D I really am basing what I say on what I learned on RV.net and ST tire manufacturer websites.
I think that a lot of the disatisfaction that I see with ST tires of one type or another really stems from the quality, or should I say lack of it.
   / Trailer Axle and Tires #10
I'm also partial and more experienced with slipper springs and 275/17.5" tires.
Believe it or not, most tire failures outside of physical damage from curbs, etc. is AGE. I have noticed some tires are made more cheaply than others.
Old tires are dangerous read HERE:
The Hidden Danger - New Old Tires | The Consumer Warning Network
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
UNUSED 16" AUGER (A51248)
UNUSED 16" AUGER...
2001 GULF STREAM CONQUEST (A51247)
2001 GULF STREAM...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
