Tractors with side mounted (articulated) mowers....
   / Tractors with side mounted (articulated) mowers.... #11
Recently hired a fellow who used a skid steer (Bobcat) with a front mounted rotary brush cutter (bush hog) to knock back tree limbs and brush around my place. He turned the deck straight up and just drove in and out around the edge of property letting the cutter blades chop the branches. Did not reach high branches but cleared enough for me to cut the grass much closer to edge.
   / Tractors with side mounted (articulated) mowers.... #13
So ....... there are, at least, two types. Texas has them up front where the loader/FEL would be and around here in Ea WA they are on the 3-point.
A quick Google search = Orsi & Lane Shark.
Just to be sure Texas has the side mounted variety also. Our county (East Texas, Tyler County) has a large Kubota with the side mounted arm and counterweights . Quite wooded here with heavy annual rainfall amounts which equals heavy plant/brush/tree growth. I've also seen them using a NH tractor but that was a few years back.
Lawyer friend of mine that attends my church was planning on buying one but haven't seen much of him since the plague. A man could have a decent side business with one of those things.
   / Tractors with side mounted (articulated) mowers.... #14
My county uses a cab, probably 100+ HP sized JD with the mower attached "midship" with a huge counter weight on the opposite side. They too do roadsides and ditches up to the landowner's fence (maybe 3 trips for that) and come back and trim the trees up to maybe 15 feet with a couple more trips....high enough for an 18 wheeler to get down the road without hitting wood. In talking with the operator, he said he loves to work my area as it's peaceful and quiet without much traffic and commotion. He does do a thorough job!
   / Tractors with side mounted (articulated) mowers.... #15
My county uses a cab, probably 100+ HP sized JD with the mower attached "midship" with a huge counter weight on the opposite side. They too do roadsides and ditches up to the landowner's fence (maybe 3 trips for that) and come back and trim the trees up to maybe 15 feet with a couple more trips....high enough for an 18 wheeler to get down the road without hitting wood......all with the tractor's tires on the hard surface of the county road. In talking with the operator, he said he loves to work my area as it's peaceful and quiet without much traffic and commotion. He does do a thorough job!
   / Tractors with side mounted (articulated) mowers.... #16
major manufacturers of side boom mowers are tiger,diamond and alamo.
   / Tractors with side mounted (articulated) mowers.... #17
The majority of the road side boom mowers in this area a mid mounted,
the pumps for the hydraulics are either hung off the pto or are tank mounted to the 3 point arms.
Most of the large ones that look to be three point are actually mounted to a heavy sub frame.
There are smaller units available for three point usage;
Betstco has three point boom sickle and flail mowers, they are kind of light duty looking,
FH-BRM Boom Sickle Hedge Cutter | Betstco Sales, Parts, and Service:
And occasionally you can find mid sized units on the used market;
mower 5.jpg mower 8.jpg mower 14.jpg mower 13.jpg mower 11.jpg Branson bracket in use 1.jpg
My 4 foot flail and it's a handfull at times on my tractor which tips the scales at around 10,000 without the mower,
you get booming up and out it will bounce the tractor quite easily.
   / Tractors with side mounted (articulated) mowers.... #18
messicks has a great video on youtube about how they mount on a tractor. they actually change out the fuel tank on the kubota they used in the video.
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Club Car Utility Cart (A55853)
Club Car Utility...
Hustler super Z zero turn (A56859)
Hustler super Z...
