Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #20,901
Here's some serious reclaiming of some farmland here on my place, I have a few overgrown acres I want to expand a hayfield, into,
Sometimes I drove in right over the brush hogging it out, and sometimes I backed in with the rotary cutter up about ten inches and then drove ahead with it down.
Either way, my Brush Bull really eats that one-to-two-inch brush up!
SR
   / Tractors and wood! Show your pics #20,902
Does anyone recognize the items in the picture labeled "Salisbury?" I'm guessing they must be a common item used by loggers. But I can't find anything about them (or similar even.)
They bite into the end of a log. Then raise the chain mid-log with tractor forks and drive away. I've found them to be much faster than using a grapple and better for putting a log on the sawmill than forks alone.
What are they?
   / Tractors and wood! Show your pics #20,903
   / Tractors and wood! Show your pics #20,904
Thanks for the quick reply!
Re: "They were extremely dangerous and discontinued there use after killing and hurting many loggers."
Seems intuitive bad things could happen fast if one of them loses its bite on a lifted log. I've used a set recently to place logs on my sawmill and so far its been uneventful. Not sure how many other ways these were used in the past.
   / Tractors and wood! Show your pics #20,905
I'd say "loggers" did a lot more high lifting than you will do lifting onto the mill. Of course any lifted log can do major damage to the human body in short order.
I don't see why something similar could not be a diy project.
   / Tractors and wood! Show your pics #20,906
A little scary to me putting logs on the sawmill with the tractor, seems things could go sideways in a hurry, I load mine on a log deck and just roll them onto the saw.IMG_3526.JPGIMG_3534.JPG
   / Tractors and wood! Show your pics #20,907
I started using a grapple to put logs on my mill. Its a very heavy grapple and I don't have very fine control of it-- leading to banging some logs on the mill. Then I started using forks-- close approach, slight tilt down, and roll onto the mill.
But the logging hooks work best/are most gentle on placing a log. At least so far. :)
   / Tractors and wood! Show your pics #20,908
Try a grapple like this. Not heavy, bites the log, and allows precise control.
gg
   / Tractors and wood! Show your pics #20,909
Looks very interesting. Only about 20 lbs heavier than my pallet forks. Around 350lb.
My HLA root grapple is ~950lbs. Really takes away from lifting capacity which is another reason I have been using forks .... this lighter grapple could be much better.
   / Tractors and wood! Show your pics #20,910
Add a grapple to your forks, and you will have the best of both worlds!
It gives me total control of the logs as I load them on my mill.
SR
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
UNUSED AGT 32-743 60" HYD GRAPPLE (A51248)
UNUSED AGT 32-743...
A1 MIST SPRAYERS RESOURCES, IN TERMINATOR 60 R LOT IDENTIFIER 42 (A53084)
A1 MIST SPRAYERS...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2024 JOHN DEERE 3039R LOT IDENTIFIER 55 (A53084)
2024 JOHN DEERE...
