Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #16,091
They don’t stick around long. As long as you’re not going straight from the splitter to the stove which you shouldn’t be anyway it’s fine.
If ants come in the house with wood in October then they have all winter to multiply, my wood is stored in basement til needed, this week is needed........
   / Tractors and wood! Show your pics #16,092
And there is part of my problem, I never have a second here to help roll!
Your right how often do we really need lumber longer then 16'..........
   / Tractors and wood! Show your pics #16,094
If I can lift a bucket full of dirt then I figure the hydraulics are close to specs, anymore pressure I'd be afraid of snapping the front axle into, probably that 20' red oak would do if it was placed on my FEL forks. But like you said gear tractors has so much more power and traction it's much better to push heavy logs..........:cool2:
I think you do really well with an L3400 and its 1,142 lb lift to height. Not the biggest by any means but you sure get a lot done with it. Good machine for what you do.
   / Tractors and wood! Show your pics #16,095
   / Tractors and wood! Show your pics #16,096
But at 20 inches out from the pin (end of loader arms) it drops to 853 lbs.
   / Tractors and wood! Show your pics #16,098
Does anyone know how to build a chicken coop or want to in this time of need, heres how........
Best Chicken Coop for Homesteading - YouTube
To me, that chicken coop is not even in the realm of being realistic,, the time and $$$$ he spent does not make sense,,
Why would you build a coop that high? the chickens have no chance of staying warm, all the heat will escape up, or through the tall walls.
Here is the one I built in 2008, it is 10X12, and works perfectly,, no one ever has to walk in it,,I change the hay(grass clippings) in the box area twice a year.
This pic is right after I installed it,, the open area on the left is a sealed feed storage closet.
The "porch" area to the right has a floor of 2X4's as slats, with gaps,, it stays clean, just from the wind, and weather.
Some of the floor is wire, I found some 1/2" square opening stainless steel wire for the floor, if the galvanized ever rusts away.
   / Tractors and wood! Show your pics #16,099
I built my chicken coop in my shed, then took it out with the front end loader,,
There are not many nails in my shed,, it is welded together,, LOL!! :laughing:
The hardwood floor on the second level is assembled with flooring nails,, I almost forgot about those nails,,
The windows are screwed in,, again, no nails,, I am not good with nails,,
I bought a pneumatic nailer when I built the chicken coop,,
   / Tractors and wood! Show your pics #16,100
This is my chicken coop it holds the chicken and the eggs..........refrigerators.jpg
Hydraulic Coupler 80 mm Pins (A52384)
Hydraulic Coupler...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
UNUSED INDUSTRIAS AMERICA 12F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
