Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #3,951
I made a subframe almost like the backhoes. Mounted a plate on that. And then extended the plate forward of the front axle where I then made a hinge. The rest of the plate is hinged here where it is lifted up and mounted to a few pieces I have mounted ont the front bumper. It's bolted here. So I can remove two bolts there, pull the two one inch pins and drive ahead two inches an the plate is off. One minute. And a lot of peace of mind
   / Tractors and wood! Show your pics #3,952
I built 6 of these handy bins last spring when the heating season was about over. They are all full and ready to go.
My bins are built using 40"x48" pallets and 16' x 50" cattle panels from TSC. I bent the panels into a square, trimmed off the extra and welded the corners. I then using fencing staples to hook them to the pallets. The empty bins weigh about 75 lbs. I figure each one holds 0.28 cords. I started by carefully stacking wood in them which is about 1600 lbs of hardwood. Without a counterweight on the back, my rear wheels got pretty light! I went to throwing the wood in after that. Thrown in like it is should be about 1150 lbs of wood.
   / Tractors and wood! Show your pics #3,954
This thread is not very active anymore. Is no one cutting wood since it is warm?
   / Tractors and wood! Show your pics #3,955
Went deer hunting with my youngest son this morning. He was teasing me, said I was tree hunting not deer hunting. Gotta multi-task, I told him. Found several easily accessible locust, Ash, and poplars I hope to harvest, and will share here... when I get the time.
   / Tractors and wood! Show your pics #3,956
It's to muddy around me to be in the woods with equipment , waiting for a freeze up here
   / Tractors and wood! Show your pics #3,957
Same goes for eastern Ontario, Canada.
I need the ground to freeze...way to messy at the moment.
   / Tractors and wood! Show your pics #3,958
I'm on vacation until the 8th. Be back to cutting after that. Before we left I was doing a lot of thinning in an area that'll get new sap tubing installed later this winter. I was mostly still in the pre-tractor phase of the project, but here's a picture of my first load on my new log wagon. The tractor isn't hitched up, but you can imagine where it goes. rps20161127_145742_554.jpg
   / Tractors and wood! Show your pics #3,959
I'm on vacation until the 8th. Be back to cutting after that. Before we left I was doing a lot of thinning in an area that'll get new sap tubing installed later this winter. I was mostly still in the pre-tractor phase of the project, but here's a picture of my first load on my new log wagon. The tractor isn't hitched up, but you can imagine where it goes. View attachment 489563
Is that a jonsered chainsaw sitting on there?
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
10 in Small Excavator Bucket (A52377)
10 in Small...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2019 International DuraStar 4300 Service Truck, VIN # 1HTMMMMN1KH714519 (A51572)
2019 International...
