Tractor won't stop with key.
/ Tractor won't stop with key. #1
brokeasajoke
320dtc
Farmtrac 320dtc is the tractor I'm working on. Replaced the shut down solenoid a couple weeks ago after the same problem. Im back to manually moving the lever to shut it down. There is no power to the solenoid so I assume its the (t4340-60242) daedong time delay. Does anyone happen to know or have wiring info as to what or when its wires have power? I don't mind to replace it, I just hate to pay $70 for a part and still have the same problem and be back to square one. I also believe the part number is now superceded to end in 243 instead of 242.
Thanks.
After further inspection the fuse had a broken "leg". I read continuity measuring on the top of the fuse through the small hole on each side so I assumed all was ok. When I began pulling fuses one leg stayed in the holder bit the fuse bridge was still good. Odd. Never had that happen before. Cheap fix.
/ Tractor won't stop with key. #3
Glad you found the problem. (y)
/ Tractor won't stop with key. #4
My MF never shuts off with the key. I have to pull out that thing that looks like a choke. 😁:rolleyes::eek::alien:
27x32 CIH Rim (A65640)
2022 EZ-GO ELITE...
YALE FORKLIFT (A63291)
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
Terramite T9 Backhoe (A65579)
Terramite T9...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
