Tractor won't start
/ Tractor won't start #1
ejb
Platinum Member
Tractor won\'t start
Help please. I have a relatively simple mechanical question, but before I go out and waste more money on tractor parts I don't need I figured I'd throw it out here...my smaller tractor is a 2wd Yanmar 276 (27HP). I bought it last year, in mint condition, with less than 500 hours on it even though it is about 15 years old...heres is the problem...it won't start (at least most of the time). I can jump start it from my truck (a big F250). and it always starts up no problem...so I figured it was the battery and went out a bought a new one...started the first time, but now it won't start anymore (w/out jumping) so then I think it must be the alternator(or is it called a generator on a tractor??)...the funny thing is that every once in a while, even if it has been sitting for a week or two, it does start right up (maybe 1 out of 20 times). So if the battery wasn't charging, it should not start 100% of the time. I really don't want to go and waste more money on a generator that I don't need.
Does anyone think that this must be the generator, or it could it be a short someplace? I am not a mechanic, but the fact that it will jump start on the first try, 100% of the time, but will start by itself on the first try 1 in 20 times has me a little puzzled. What would be the best way to "prove" that it is or is not the generator before I put a new one on.
Thanks much all.
/ Tractor won't start #2
Re: Tractor won\'t start
ejb, Do you have a multimeter? Check the voltage on the battery, without the tractor running. A fully charged 12 volt battery should have about 12.6 volts. Then get the tractor to running at a fast idle at least, and check the volts at the battery terminals again. If the alternator or generator is working properly, you'd expect about 14.2 to 14.4 volts, if I remember correctly. Now of course, I'm telling you the quick, cheap way to get a fair idea with a $10 meter, so before you experts jump, yeah, I know, there are more precise ways to check exactly, and I use a $180 clamp meter myself, but don't know what equipment ejb has./w3tcompact/icons/laugh.gif
And ejb, I'd check to make sure the cable connections at the battery (and the other end for that matter) are clean and tight. In fact, a poor connection at the battery would be the first thing I would suspect.
Bird
/ Tractor won't start #3
ejb.. just to add to birds post check your earth and also at your starter too ,checking the cable as you go .could also be a bad battery (even tho it's new it can happen)you also could put your battery on a chager and see if it makes any diffrence
cya
JD Kid
/ Tractor won't start #4
I can add only my experience to the excellent advise offered already. My B6100 vintage a bit older than yours got to doing the same thing. Replacing the battery did not fix the problem. What I did find was a modular (molex?) plastic connector that carried a heavy wire from the ignition switch. The male/female portion of this connector was burned. I made a splice outside the harness and my mystery was solved. Sounds easy a pie, but it took me a long time to trace that one down. Poor electrical connections generate heat and are a tell-tale sign of a problem.
/ Tractor won't start #5
jdkid.
Like bird has stated check all connections and for the may be lose or rusty,also put little grease on your battery connection after cleaninig.
Check under your dash where the key swtich located also,if all seem find a little spray would help to clean and coat.
Check your wiring to your lights also,for you might have a bare wire. I had a Speedex tractor and it did the samething in which you are facing,and it was do to a bad ground.
Take care and good luck.
Thomas..NH
/ Tractor won't start #6
Agree. Checking connections and cables is a good thing to do. I'll add a couple of notes. First, it's not clear if 'not starting' means 'absolutely dead' or 'not enough cranking.' If it's absolutely dead, the safety switch, relay and related components may be involved. Components with switches and contacts are suspect when intermittent problems are present.
If the cranking is low, a thing to sort out is whether the starter motor/solenoid isn't getting adequate voltage, or whether the battery voltage is low. Jumping the tractor will put a flash charge on a low battery, so battery voltage should be measured before jumping. If the battery voltage is low, with a new battery, the likely problem is that it's not getting a good charge. Bad connections between the alternator/regulator and battery could be the problem, these connections should be checked before replacing components.
Since this is described as an intermittent problem (the nightmare of technicians), the problem might remain even after checking and cleaning all lines in both the starter and battery and alternator lines. If the problem remains, contact failure in the starter relay or solenoid might be the problem.
/ Tractor won't start #7
Hi ya's
another thing about this is watch out jump starting .with more and more things haveing computer chips,radars and the such like watch out for spikes!! ok your tractor may not have these things on them but what about your trucks?
the guy that used to work on my case IH told me if i was going to jump start do it this way
turn off both (tractor & truck or what ya jumping from)
put on the jumper cables ,them start the good battery and leave running for about 1/3 -1/2 an hour ,then turn off your truck. remove the cables ,and try starting then
useing spike gard(?) cables is even better ,how many of us see big sparks putting cables on?
cya
JD Kid
Thanks all for the help so far..."not starting" means dead, completely dead, doesn't even turn over or even attempt to (but the dummy lights do come on)...just this morning I took off the battery connectors, clean them up real good and put them back on...still no start...then I start manipulating all of the wires I could find, looking for cracks or rust (of which I could find neither), but then lo and behold the tractor started right up...ten times in a row even...so I think I have determined that it is not the generator/alternator, but instead a short someplace that I have yet to find (but did manage to fix at least temporarily)...guess I'll have to really inspect each and every wire to find the one that is causing the problem, but at least for now it is working for me.
Anyone have a secret for finding which wire may be causing the problem??
Thanks all for the help!
/ Tractor won't start #9
hi ya
ok so the light come's on,when you turn the key does the light dim/or go out?? (when it does not start)with moveing the wires about you may find (if push on fittings)that one of the crimps on the wires is lose and may need soldering on better also the lug that the fitting pushes on to may have rust or salt build up on it (moveing the wires may have broken the build up and let the power flow though )I had kind of the same thing with a inline fuse to my loader i looked at it and it looked clean (brass ends) it was not untill i rubbed them up with some fine sandpaper did the power flow
cya
JD Kid
/ Tractor won't start #10
ejb, if the dummy lights come on, I think I'd be looking at the wire from the starter switch (ignition switch) to the starter solenoid. And of course, if, when you hit the starter, power gets to the solenoid, then I'd be wondering whether it's the solenoid that's bad. Good luck.
Bird
/ Tractor won't start #11
ejb.
Maybe you have a dead spot in your starter?
Can you rotate your engine by hand or other means a half turn than try your starter?
Do you have brushes in your starter,if so check those.
I would be most interested in your out come.
Good luck.
Thomas..NH
/ Tractor won't start #12
Since you replaced the battery, my suspicion is that it is the starter. Starters being DC, have brushes. Check the brushes for sure, they can usually be replaced. Knowing the load the starter draws (current or amps) while its cranking tells you a whole bunch about the condition of a starter, but thats where its trickier for you to make the test. Pull it and go to NAPA or even a Kragens and have them test it. To much current draw as detected by an amp meter tells you you have short circuiting within the starter. The condition of the cables is something that is usually quite obvious, clean connections are simple and should be done occasionally anyway. The fact that you can get it going with jumpers tells me you have bad brushes or an armature with "opens" in it. If its the armature, your probably going to have to bite the bullet and get another starter. Your only other possibility is the field coil, but in all likelyhood, thats not it. Rat...
/ Tractor won't start #13
The normal way shops do it is to charge $50 an hour and then hunt around like you are doing. /w3tcompact/icons/smile.gif
Start with the battery cables, remove from battery and use tool from auto supply to clean terminal and battery terminal. Be sure the other end is clean and tight. Turn the headlights on and then try to start the engine. If the headlights stay on, the problem is in the low current side of the starter circuit or interlock circuit. Easy to follow through if you have a schematic of it. On my tractor the PTO must be disengaged and the shuttle shift must be in neutral. What ever the rules are for your tractor, check those switches for loose wires or to be sure that you can see the switches being opened and closed as you move the lever. The ignition switch is not out of the question, but can be eliminated by using a test light on the switch output and then on the starter solenoid terminals.
There is a reason the old tractors used a crank to start. The resulting broken arms caused all this mess to be added just to replace a defective arm. /w3tcompact/icons/wink.gif
>>The normal way shops do it is to charge $50 an hour and then hunt around like you are doing...
Thats what I was afraid of...and they will probably just keep on replacing things until something works to! which is why I posted the question here and got many useful suggestions to try.
/ Tractor won't start #15
Now it sounds like you've got the opposite problem. It works, but you know there's something wrong and now you can't make it stop working. That's the other half of the intermittent problem nightmare I remember from my tech days in the Air Force.
As I recall the approach was: Blow air and use contact cleaner on everything. Take off each contact inspect, pull the terminals a bit and use contact cleaner. That's seems to be what you're doing. The object here is to either completely break it so you can find the problem or find that it still works and then force yourself to forget about it.
There is a testing approach that seems more scientific but often takes a lot of time and produces no conclusions. The approach would be something like taking the hot wire off the starter-motor and jumping the starter switch. A voltmeter on the starter wire should show battery voltage. Wiggle individual wires and connections and see if the voltage drops out any place. A jumper probably shouldn't be left on for very long at a time.
Of course, the testing approach can turn into the 3rd half of the tech nightmare (teching nightmares come in three halves). To illustrate: I used to work in a BSA motorcycle shop. We had a bike come in that was blowing fuses. Of course, we couldn't blow a fuse in the shop. Everybody had a go at it--everything wigglable was wiggled. We took it for test drives and it would blow fuses, but not in the shop. Finally we noticed that the only time a fuse blew is going downhill while applying the rear (but not the front) break. We eventually found a short in the wiring harness where it went over the steering crown. Applying the rear only brake shifted the weight forward, spread the forks forward and caused a short. The forks didn't spread if the front brake was also applied.
Duh, I think we each had about a half-week's work in it and got about 10 cents an hour. Unlike most shops, the owner didn't charge customers for much time mechanics spent figuring out things.
What I'm saying is that if your problem has a cause like that, you're not going to find it easily. The best approach might be to either live with it or get rough and hope you cause the problem to become permanent. At least you got past the approach of first choice used by Air Force techs and typical mechanics. Just start replacing big pieces one at a time and hope one piece contains the real problem.
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
Atspower Mini Excavator (A60352)
Atspower Mini...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
JOHN BLUE TANK SUB FRAME (A63291)
JOHN BLUE TANK SUB...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59912)
2025 PJ CC162 T/A...
2021 Harley-Davidson FLHP Road King Motorcycle (A61574)
2021...
