Tractor wont start wiring a mess
/ Tractor wont start wiring a mess #1
benwilliamson
Massey Fergusen 135
I cannot get my tractor to start. It has worked fine for 4 years. This spring I started it, ran for about 5 minutes then died.
Massey Fergusen 135, 1976
/ Tractor wont start wiring a mess #3
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Parts/Repairs Forum. You'll get a better response there. ;)
/ Tractor wont start wiring a mess #4
Gas or diesel?
what happen when you try and crank the engine?
/ Tractor wont start wiring a mess #5
Sounds like no fuel...either a blockage or air bound...change your fuel filter...and, if a diesel, drain your water separator (if you have one in the system).
After it ran, then stopped...what happens when you try to start it now...just cranking? Any smoke?
/ Tractor wont start wiring a mess #6
We're going to need a far longer description of the symptoms...does it crank...and what you have tried...too many things it could be.
did you cut off the fuel last fall and forget to open the fuel this spring.
on the MF165 I used to own, there was a single electrical safety interlock and the wire kept slipping off killing the engine
why do you think "wiring a mess"
awaiting more details from you.:)
/ Tractor wont start wiring a mess #7
anything yet? waiting for more info.
soundguy
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
Land Pride 80in Rotary Brush Cutter Tractor Attachment (A61572)
Land Pride 80in...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
207276 (A52708)
207276 (A52708)
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
