Tractor won't move
/ Tractor won't move #1
Battleboy
LS MT125
HI:
I have a2022 LS MT-125 with a backhoe and an FEL. I did the fluid change at about 53 hours as I was doing work at the 50 hour mark and wanted to finish the job. NOw with 56.4 hours, I was backing the tractor up after warming it up and it just stopped. Neither pedal would make the tractor move and they BOTH seemed to have much less "resistant" to being pressed. I crawled underneath and the rods that are attached to the pedals move when the pedal is pushed and can see they are attached to a spring but, can't see much above that. FEL and Backhoe both move as desired, it's the drive that's not working.
I'm not a mechanic, all of the fluids are at level, please help.
/ Tractor won't move #2
I’m not familiar with your tractor, but if it has multi ranges (s-m-h) make sure it’s not in between ranges. Mine has neutral I between the ranges, it will act as you describe yours if I dong get it properly into selected range.
Thanks, will check that. I might have hit it pulling the cover off.
me too. I'll get over this "stupid" feeling when the repair bill doesn't come in.
Bobcat SC72 (A64127)
2009 CATERPILLAR CP44 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
